Sponsored by: Real Truck
Pulling out small trees?
Old Oct 31, 2011 | 10:08 AM
cbzdel's Avatar
cbzdel
Last year on my property I took my old dying 1993 F150 and just floored it and took off with a rope tied to the reciever and the base of these small trees (small as in 5' to 10' tall) and everytime it would ripe them clean out of the ground, roots and all. My friend just bought a house and has some of the same small trees would like them removed. Well know I have my few F250 and his property is much smaller, I cant get a running start on these. What would be the best way to pull these things out without tearing up his yard?
I was thinking about just digging around the base and then tie it up to the truck. I was thinking if I put it into 4wd low and just start slow it should rip them out? Possibly haha.. What does "tow/haul" mode do? Would I benefit from using this mode?
Old Oct 31, 2011 | 10:16 AM
maverick22's Avatar
maverick22
Without tearing up his yard? A shovel and axe/saw.
Tow/haul won't do you any good - it changes shift points and provides engine braking when towing/hauling.
Old Oct 31, 2011 | 11:10 AM
cbzdel's Avatar
cbzdel
it was worth a shot asking haha, my buddy just keeps saying you have a V10 you can pull them out just idling
Old Oct 31, 2011 | 11:16 AM
twags6's Avatar
twags6
We've pulled quite a few out in my yard without ripping up the grass. Just try to stay on even ground so all tires are getting the same amount of grip and keep it in 4 lo like you said and put the truck in 1st gear. Digging it up like that really does help too.
Old Oct 31, 2011 | 11:50 AM
dkf's Avatar
dkf
Use a long enough rope so your not on the grass if possible. Wetting the ground around the roots and digging out around the roots helps the tree to pull out easier.
Old Oct 31, 2011 | 11:56 AM
tuscany's Avatar
tuscany
I myself have not found to be owner (house or vehcile) friendly to do it that way....tough on the ground and vehicle
Old Oct 31, 2011 | 12:13 PM
thomabb's Avatar
thomabb
I park the dump trailer so the front of the box is beside the tree. Chain the tree to the box and raise the dump. Easy Peasy. Find a home improvement or landscape store that will rent you a dump trailer.
Old Oct 31, 2011 | 01:47 PM
raidscsi's Avatar
raidscsi
I used a 10ft chain to the receiver hitch, ripped out some 2-4" trees, 4-low, 1st gear, didn't even have to push on the gas.
Old Oct 31, 2011 | 02:56 PM
sammy77's Avatar
sammy77
Just pulled some trees down this weekend and that's exactly what I did. Worked very well.
Old Oct 31, 2011 | 03:07 PM
Superduty ROCKS's Avatar
Superduty ROCKS
Be careful with that chain, you might end up having to replace your tailgate and bumper. Ask me how I know. Thankfully no one was standing near.
Old Oct 31, 2011 | 03:31 PM
cbzdel's Avatar
cbzdel
Thats why I stick with the cloth straps WITHOUT metal hooks/ring on them
Old Oct 31, 2011 | 04:17 PM
twags6's Avatar
twags6
Straps with looped ends and a clevis hitch are the safest by far!
We use chains, but NEVER yank on them or leave more then 6 feet of slack! If it doesn't pull out easy, we dig more or get the skid steer to lift it out. Plus the ones we use are at least grade 43 3/8" or higher, none of that grade 30 proof coil crap.
Old Oct 31, 2011 | 09:44 PM
exiled's Avatar
exiled
I use grade 70 chain. I put my truck in 4l lock out my hubs manually and shift the tranny into 3rd. By using 3rd less likely to spin a wheel. Haven't had any trouble yet.
Old Nov 1, 2011 | 09:15 AM
BareBones's Avatar
BareBones
Haven't done any trees, but quite a few bushes. Just granny low and idle on off.
Old Nov 1, 2011 | 11:17 AM
kd0axs's Avatar
kd0axs
Bushes aren't even worth using the truck. I just pull them out with the winch on my 4 wheeler.
A couple weeks ago I was removing a large branch for a relative. It had fallen down in a storm earlier this summer but was still attached to the tree pretty good. (Leaves were still green) It was in a position that it wouldn't have really been safe to go up on a ladder and cut it down so I just put a strap around it and pulled it down with my truck. I just left it in 2wd and barely touched the gas.
