Knocking Sound at idle?
Old Oct 30, 2011 | 09:37 PM
mr.fordneck's Avatar
mr.fordneck
When my truck is sitting at a light or at idle, the engine produces a knocking sound. I do not think its a suspension part since I am sitting still. I checked my oil and its not low. It is a hollow sound but sounds like metal to metal. 1990 5.0 efi. Just had a new head gasket and intake put on and valve job professionally done so I think they'd tell me if my pushrods were bad. Plus they looked fine whe I saw them. It sounds like this 1990 F150 5.0 V8 engine clanging.MPG - YouTube but much quieter. Please help. Truck has not run any different than normal
Old Oct 30, 2011 | 10:54 PM
Rico47635's Avatar
Rico47635
I'm no expert, but that sounds like a broken rocker arm to me. Did it make the noise before you had the valve job done?
Old Oct 30, 2011 | 11:11 PM
mr.fordneck
Did it make the noise before you had the valve job done?[/quote]
nope. just noticed it today
Old Oct 30, 2011 | 11:12 PM
mr.fordneck
All my rocker arms were fine before the work
Old Oct 31, 2011 | 05:52 AM
lew52's Avatar
lew52
Sounds like a rod bearing to me .....
Old Oct 31, 2011 | 08:33 AM
Bankrupter's Avatar
Bankrupter
This is what Id think also based on that vid....
You said the vid is not yours and your issue is quieter. Can you get that posted somewhere ?
Old Nov 17, 2011 | 10:35 PM
mr.fordneck
this is my truck What is wrong with my engine Pt. 1 - YouTube
Old Nov 18, 2011 | 06:43 AM
danr1's Avatar
danr1
First video is a burnt valve, can't hear the noise in yours. Record it again however next time don't say anything.
Old Nov 18, 2011 | 10:11 AM
Kemicalburns's Avatar
Kemicalburns
what oil filter are you running and grade oil?
did the lifters get replaced when the head job was done?
does it start when the motor is still cold or does it show up later once it reaches temp. have you checked that the exhaust manifold bolts are tight along with the collector bolts to the y pipe?
Old Nov 18, 2011 | 02:12 PM
mr.fordneck
here is what you want What is wrong with my engine Pt.3 - YouTube
Old Nov 18, 2011 | 02:14 PM
mr.fordneck
ok lifters have not been replaced. Purolator Oil Filter 10w30 oil. It does this no matter if engine is cold or not. ill check the exhaust bolts again. last time i checked em a month or so ago they were tight
Old Nov 18, 2011 | 02:17 PM
mr.fordneck
here is my truck
Old Nov 18, 2011 | 02:42 PM
danr1's Avatar
danr1
Think I can hear it but hard to be sure, record it again but from standing outside hood up not sitting in cab. Noises tend to be hard to diagnose even when heard in person, even harder yet recorded played on internet!
Give us three conditions,
While at "idle"
give is couple few "revs" so we can hear rpm changes and effect of same (no need go crazy high with them)
and then high rpm speed, while held "steady" at say 1800rpms.
Connect a vacuum gauge directly to a port on the intake, include its "reading" in video/audio recording please.
Old Nov 18, 2011 | 04:52 PM
300ci Legend's Avatar
300ci Legend
Sounds like a rod knocking to me my friend. Sorry to bring bad news :/
Old Nov 18, 2011 | 11:22 PM
mr.fordneck
That video in your link is not the same video as I posted. That truck is not my truck. there are seperate videos on this thread
