Valve Cover Problem
Old Oct 30, 2011 | 09:26 PM
HoustonGuy's Avatar
HoustonGuy
Valve Cover Problem
At this moment I am checking my rocker springs. So I need to take my valve cover off. I remove all of the bolt accept one but it was the only bolt that wasn't OEM and it was rusty. It turned a few times but only got harder and harder to turn until I accidentally rounded the edge with my ratchet , because at that point it wouldnt turn any more. I cannot heat it up because every time I do it catches on fire and i cant pull the cork gasket out which goes up in flames. I put vice grips on it and it still wont move. what should I do?
Old Oct 30, 2011 | 09:44 PM
sinistry's Avatar
sinistry
Start spraying it down with pb blaster for a couple days then come back and try again, if that does work you try welding a nut to it
Old Oct 30, 2011 | 09:45 PM
sinistry's Avatar
sinistry
If that doesn't work*
Old Oct 30, 2011 | 09:50 PM
HoustonGuy's Avatar
HoustonGuy
Yea, im sprayin some on there. how long does the b'laster take to work
Old Oct 30, 2011 | 09:56 PM
sinistry's Avatar
sinistry
I guess it wound depend on how rusty it is. Longer is always better so if possible let it sit for a day spraying regularly to try to work through the rust.
Old Oct 30, 2011 | 11:16 PM
blkmesamtman's Avatar
blkmesamtman
If you can get to it with a hammer, try giving it a couple of raps squarely on the top. Most of the time this helps loosening it a bit and also lets the penetrate seep in. Also the idea of welding a nut on topmight work. The heating and then cooling will sometime loosen a bolt.
Good Luck!!
Old Oct 30, 2011 | 11:28 PM
wdfp's Avatar
wdfp
If you can get it to move, tighten it first, then loosen, when it gets hard to turn reverse directions a little then go some more.. Back and forth usually gets them out when they are like that...
Old Oct 31, 2011 | 09:59 AM
mark a.'s Avatar
mark a.
Hit it hard with a punch a few times and work it back and fourth, repeat till it loosens.
Old Oct 31, 2011 | 11:04 AM
HoustonGuy's Avatar
HoustonGuy
I wish I could heat it up but the gasket catches on fire, i just hope that the penetrating catalyst is reaching the threads through the gasket.
Old Oct 31, 2011 | 12:00 PM
Aaron-71's Avatar
Aaron-71
2X on this and what others have said.
Grab yourself a punch. Most likely, you're not able to hit the bolt on the head at the right angle due to the messed up angles of the V engines.
Hold the punch parallel with the bolt angle into the head and give er a couple of good swings with your favourite hammer. Don't bash the **** out of it, but enough to vibrate the threads inside the head and loosen them a bit.
The next thing is to use the weld a nut idea on to the head of the bolt. It may be a pain if you can't get things to line up correctly and may actually make things worse cause then you can't get your ratchet wrench socket on there due to overlapping corners (depends on how stripped the bolt head is), but you should be able to at least get a box end wrench on the welded nut.
Loosen the nut, tighten it back up, loosen it some more, tighten it some more. Hit it with more PB Blaster, and let it sit. Repeat. It's all about trial and error when it comes to old rusty bolts.
Whatever you do, don't light the PB Blaster on fire. That stuff is HIGHLY toxic when used, and should be used in a ventilated room/area at all times. Lighting it on fire or allowing the chemicals to catch flame will only make things worse! Don't do it! I've done it before, and it aint pretty!
Old Oct 31, 2011 | 12:19 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Very good advice. Reps sent.
Old Oct 31, 2011 | 12:51 PM
Poison Oil Racing's Avatar
Poison Oil Racing
Originally Posted by HoustonGuy
...i just hope that the penetrating catalyst is reaching the threads through the gasket.
Oh, it is. Don't worry.
Old Oct 31, 2011 | 07:42 PM
four-sixty-power's Avatar
four-sixty-power
Another tip/trick:
Standard and metric sizes are pretty close. I've rounded heads off before and sometimes its not too bad, I've gotten cheap socket sets as gifts that are perfect for operations like these. Get the nearest size metric socket(if the rounded bolt is standard), and hammer it onto the head of the bolt or nut, attach ratchet or breaker bar and loosen, like others have said work it back and forth to loosen, I find this grips the bolt tighter than a visegrips and there is no heat issues to deal with.
Use cheap sockets, the first time I tried this I broke a brandname socket, which isn't bad because of the replacement policy but I could have done without the extra trip to the store. It did get the bolt out but split the socket up the side in the process. Now you have a use for cheap poor quality sockets
Resendiz
Oct 18, 2016 08:56 PM
cougfan87
Apr 8, 2016 09:18 PM
Captain Jazz
1983 - 2012 Ranger & B-Series
Dec 20, 2009 08:07 PM
wiseguy
Feb 12, 2007 08:23 AM
ChargerHemi
May 25, 2006 10:50 AM
