so it turns out i can buy just the tone ring, does anybody have any knowledge or input on what i'm in for for an install... any info is great!!
As always thank in advance!
yeah i did darin, thanks for that..it looks pretty simple indeed, hopefully the new ring will press/tap right on.. looks like i all i gotta do is pull the main gear off and put it right back together.. now i gotta find that website i found a ring for 50 bucks or something...
kubic
you can pull the vss and rotate the wheels to inspect that ring
i'll try to remember to take pics of the process and hopefully post them if all goes well.
its not to difficult. i have done the one in my 95 f250 after i bashed the cover in on a rock. pull the cover, pull the axles, remove the carrier bearing caps ( dont mix them up as they are machined to fit ) pull the carrier ( a big prybar works wonders ) dont forget to clean, locktight and torq. the ring gear bolts.
on an auto it will mess with the shifting as the trans dosent know when to shift and how hard, plus the rear abs has a fit. on the man trucks it will only affect the speedo and rear abs
