replacing tone ring
Old Nov 3, 2011 | 07:44 AM
bryanlindborg600's Avatar
bryanlindborg600
Thanks Darin, funny thing is i remember going to website a day or so ago in my mix or numerous sitse trying to find the tone ring itself. I guess i overlooked that nice bit of info.. i needed someone to point out how spacey i was being i guess...anyways thanks for the help!
Old Nov 26, 2020 | 06:02 PM
Dawgsterpepper's Avatar
Dawgsterpepper
Still searching
Has anyone found a site with pics and instructions on how to replace a speed sensor ring in a 1995 F 150 5.8 L Tranny E40D? First ever question
Old Nov 26, 2020 | 07:40 PM
97-psd's Avatar
97-psd
First, welcome to FTE
Second, this may not be the best forum for the question since this forum is geared towards trucks with the 7.3 Diesel engine.
Third, we are usually pretty helpful so here is my best thought. Considering the truck is a 95 it may use a similar tone ring. In order to replace it, you have to remove the rear gear set. You will need to remove both axles to do so. Once out, you should be able to drive the tone ring off the ring gear
usually the tone ring is pretty reliable unless something breaks and grinds the teeth off. If this happened to you, you may need more than just the tone ring. This is also predicated on the idea that I am remembering the location of the tone ring correctly
Old Nov 30, 2020 | 07:34 PM
Dawgsterpepper
Thanks Greatly appreciated
Old Jun 1, 2023 | 08:53 AM
thehands's Avatar
thehands
2nd Gear
so basically pull the axle shafts you don't have to pull the tires off just the inner axle
pull them out 6-8 inches
pull of diff cover
keep in mind which bearing cap goes where as they are machined to fit
pull the caps
pull out the whole differential it comes out with the bearings make sure they go on the same way
bang off the ring gear with a hammer and a screwdriver
heat up the new one to 400 degrees (easy oven made it super easy took ten minutes and heated it up like a charm without warping it.)
drop it into place
reinstall differential and caps to 85lbs
reinstall axle shafts retighten to 70 lbs
reinstall diff cover i used 1 minute black oil resistant seems to work well
use 75-140 synthetic around 3.5 quarts and if you have a limited slip use 10 ounces of the limited slip differential additive. reinstall fill plug
test it.
this is for the sterling 10.25 dually with the limited slip differential.
i bought mine on 5/21/2023 for around 90$ from ford. before replacing the tone ring i replaced the speed sensor 3 times the psom or speedometer the connections for both but it was the tone ring.
havent seen a list thought id post it. so people can find it quickly since this came up first for my truck. and this is what i learned searching the internet.
My speedo was bouncing a little until about 45mph then after 45 it would go anywhere from 0-85mph every second.
it was a little rusty i cleaned it up but it didnt help so i changed it. Now it's dead steady and works
​​​​​​Beautifully.
Good side
Bad section
JRC99408
51
Mar 15, 2021 08:25 PM
firstrider
Mar 25, 2018 04:36 AM
riverrat41
Texas Chapter
Nov 11, 2011 04:07 PM
PinkStroker
91
Nov 13, 2008 10:51 AM
