got a PROBLEM
Old Oct 30, 2011 | 01:15 PM
jonnyboy78023's Avatar
jonnyboy78023
got a PROBLEM
here"s the problem, i have an 04 f250 crew cab 6.0. i have three gauges on my pillar, egt, boost, and fuel pressure. about 2 weeks ago my fuel pressure would jump up to 100 psi and bounce around then settle back at 64 psi where its pretty much always at. i don't drive my truck everyday so i didn't think anything of it. but this weekend i drove it to the coast and it got a little worse. at idle it was pinned at 100 but when i put it on cruise at 70 or under any kind of load it would sit at 64. well on the way back from the coast it was pretty much pinned on 100 psi unless i really got on it it would drop slightly then jump back up again. with the koeo (key on engine off) my gauge reads a solid 64 psi but as soon as i start it, its back up to 100 psi. any ideas i cant pin it to anything right off hand. all help is appreciated thank you.
Old Oct 30, 2011 | 01:37 PM
BLADE35's Avatar
BLADE35
Change your fuel filters
could be a possibility of a bad fuel press sending unit
Old Oct 30, 2011 | 01:51 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Fuel filters would cause low pressure vice high pressure. I second a possible bad sending unit or possibly a bad IPR.
Old Oct 30, 2011 | 01:53 PM
jonnyboy78023
fuel filters are brand new maybe a 1000 miles or less. how could ipr make me have a high pressure in my fuel filter housing
Old Oct 30, 2011 | 01:54 PM
jonnyboy78023
sending unit is good also, had it checked with another fuel pressure gauge
Old Oct 30, 2011 | 05:24 PM
npccpartsman's Avatar
npccpartsman
Did you hook up your sending unit to another truck and gauge or just hook another gauge to your sending unit?
Old Oct 30, 2011 | 05:30 PM
jonnyboy78023
no i put an external fuel gauge thats mechanical, and i plugged it into the test port where my sending unit is.
Old Oct 30, 2011 | 05:34 PM
npccpartsman
If you're getting 100 psi there then you have some kind of a regulator problem or a return line plugged and a damn good pump--LOL.
Old Oct 30, 2011 | 06:01 PM
jonnyboy78023
the funny thing is i dont think i have a return line problem you can look at the fuel gauge and kind of see it shaking a little, and if you put your ear up to the fill neck of the gas tank it sounds like im filling up my tank with a fire hose
Old Oct 30, 2011 | 06:28 PM
npccpartsman
Have you installed the blue spring upgrade or modified your fuel pressure regulator? I'd be looking inside it to see if the regulator plunger has gotten out of place. It does happen.
Old Oct 30, 2011 | 06:42 PM
jonnyboy78023
no i havent done anything to the regulator or the blue spring. when you say the plunger your talking about what slides into the fuel filter correct?
Old Oct 30, 2011 | 06:45 PM
npccpartsman
The part that slides into the fuel filter is a stand pipe. The plunger is inside here with the spring: Page 30: Fuel Supply System
Do a search for blue spring upgrade and you'll find tons of information.
Here's a good thread with pic's from the diesel stop: http://www.thedieselstop.com/forums/...ctures-278882/
Old Oct 30, 2011 | 06:52 PM
jonnyboy78023
what about the fuel inlet check valves on the heads? if one of those were bad they would create high pressure in the fuel filter house right? ill pull the regulator off tomorrow what should i look for in there to be bad?
Old Oct 30, 2011 | 07:02 PM
npccpartsman
No they would not. The fuel pressure regulator is what controls fuel pressure. If the inlet check valves on the heads were blocked your truck wouldn't run because it wouldn't be getting fuel and besides that, they are to keep fuel IN the heads not out of the heads. And lets don't mention that fuel doesn't flow all the way through the heads anyway since the heads are plugged at the back creating the safe effect as "blocked inlet valves".
Old Oct 30, 2011 | 07:09 PM
jonnyboy78023
alright man thanks for the prompt answers i will let you know tomorrow when i check it out. one last question, the fuel filter in the secondary housing wouldn't cause high fuel pressure would it? im just trying to rule out all possibility's so when im under the hood i can do it all at one time
