help
Old Oct 29, 2011 | 09:09 PM
BIG ATS's Avatar
BIG ATS
help
i just brought a 1997 power stoke 4 dr truck with the lxt package 4x4 auto i have a couple of questions frist is if i have brake turn signals working but no tail light what do i check for. second question is the radio wiring harness was cut badly where do i find a diagram to find out which wires are what. thrid question is i have a small fuel leak from top running down the right bank to the ground i need some pointers and help please
Old Oct 29, 2011 | 10:57 PM
Mdt1992's Avatar
Mdt1992
on your running lights make sure your fuses are good in the cab, does the insturment cluster light up? how about headlights?
radio here are two schematics first is with the premium sound option
then without it
fuel leak could be a number of things the fuel pump is right there along with multiple lines and o-rings best thing to do is clean it up and let it run trying to look for the leak.
Old Oct 29, 2011 | 11:01 PM
BIG ATS's Avatar
BIG ATS
help
my headlights work and dashlights work brake lights work turn signals work no tail lights
Old Oct 29, 2011 | 11:27 PM
Chris56ford's Avatar
Chris56ford
lost
On your tail lights, you could have the tail light filament of the bulb blown or a connection problem. Pull the bulbs and check them, you can also check for power on the wire at the tail light housing.
Old Oct 30, 2011 | 12:50 AM
madpogue's Avatar
madpogue
Do the front parking lights work? Side markers?
Old Oct 30, 2011 | 06:46 AM
427 fordman's Avatar
427 fordman
fuses all checked? Fuel leak like mentioned, just have to dig in there and find out where its coming from.
df85732
Jun 9, 2018 03:49 AM
oldschool84f150
Oct 13, 2009 12:07 AM
1974oneton
Sep 15, 2009 06:44 PM
53Trucker
Sep 20, 2005 11:25 AM
jlancaster
Aug 7, 2004 08:52 PM
