Calling all AE/hpop experts
I was playing with my AE tonight doing some WOT data logging. Take a look at these graphs and tell me if I'm interpreting this correctly.
It looks to me that my hpop is weak, My duty cycle maxes out at 65%.
Go easy on me, I just got AE and I'm still learning....
I'm no AE expert, but it looks to me like you're maxing out the IPR at 65% and only getting around 1500 psi ICP to show for it. When you let off the skinny pedal, the injectors don't need as much oil so ICP pressure spikes up since the oil is still flowing but is no longer needed.
Looks like you're in the market for a better HPOP.
How High should it go ???? I would like to know also.
I haven't figured it out yet on my AE, but will look more into it in the morning.
Is that why my truck has low end, mid end and kinda falls off on high end...
SORRY FRANK.. didn't mean to jack your thread.. just would like to know also..
ICP should go close to 3,000 psi for a healthy pump. The IPR Duty Cycle should stay closer to 50% range doing this. That is what a good even pull will show with a healthy system.
Here is a graph to look at. It looks a little messy with all the data. RPM and ICP use the left vertical axis, MPH and IPR DC use the right axis.
Here is the same data only looking at ICP and IPR DC.
Alas young Frank it is time to say a tearful goodbye to you're trusty old friend she's trying her hardest to keep up! But it's gonna be helping you out in fuel costs alone! a t-500 or Adrenaline may give you a pretty short pay back, with all that moving around you're doing
Jim & fat Monty
Jim & fat Monty
Jim & fat Monty
Jim & fat Monty
I ordered a hpop line disconnect tool from Clay with my AE, I had a feeling it would come to this.
I saw a 3 mpg jump when I installed my adrenaline, onto stage I sticks with similar high duty cycle % as you are seeing but just a smudge mo-better icp numbers! I'm really surprised you aren't Seeing some random P1211's with much IPR movement? I bet you will be soon!
Now abought those 175/146 single shots you were needing for X-MAS? Well MontyClaus says go on and get them too! You were naughty in all the nice ways....
Jim & fat Monty
Jim & fat Monty
Jim & fat Monty
Jim & fat Monty
