AE help.
Old Oct 29, 2011 | 07:04 PM
sand_fiend's Avatar
sand_fiend
AE help.
Im trying to learn AE. what is this error and why am i getting it..
I can't seem to find the live data and how do you record it ??
http://i302.photobucket.com/albums/n...fiend/test.png
Old Oct 29, 2011 | 07:47 PM
woodnthings's Avatar
woodnthings
You are on the Onboard Test Results tab. Move over to the Live Data Meter tab (second one from the left)
Take a look at this video I put together to walk you through AE.
Autoenginuity Video - YouTube!
Old Oct 29, 2011 | 07:56 PM
woodnthings
Look at your picture, see where the green circle is? That is the Live Data tab. You can view data in the other tabs to the right (next three) in different views too.
Old Oct 30, 2011 | 04:11 AM
Skip1970's Avatar
Skip1970
thanks guys im trying to learn this ae too, its very difficult
Old Oct 30, 2011 | 10:38 AM
woodnthings
Using AE is actually not hard. I think you will find out that it is more difficult understanding your trucks systems and what to look for in AE to diagnose the systems. Having a thourough understanding of how the truck and components work makes it a whole lot easier.
I always recommend having the Power Train Diagnostic manual for your specific year. It is a priceless piece of information that will help make you understand the systems. You can pick them up on eBay if you look around.
Old Oct 30, 2011 | 11:58 AM
HD Rider's Avatar
HD Rider
Rep police got me!
Excellent tutorial Ken!
Old Oct 30, 2011 | 02:39 PM
woodnthings
Originally Posted by HD Rider
Rep police got me!
No worries! Thanks for the thought though.
Old Oct 30, 2011 | 03:18 PM
Skip1970's Avatar
Skip1970
it makes me mad i have to write the codes down on paper becuase when i unplug the at from the truck they disappear on the computer ae program!
Old Oct 30, 2011 | 03:26 PM
woodnthings
You can print out and save the codes. I believe if you are on the code screen, you can select to save it as a file. Then when you connect to a printer, you can print it, or pull it up at a later time.
Old Oct 30, 2011 | 03:29 PM
Skip1970's Avatar
Skip1970
you can save it as a file? is it a txt file or what? i dont think you can, i was looking for ways to save it and didnt find anything.
Old Oct 30, 2011 | 03:35 PM
woodnthings
I have done it for others. I may have to get out the other computer to figure it out again. Not something I do a bunch as I am usually not chasing codes. Most often it is one code or just a playing session I am doing.
Old Oct 30, 2011 | 03:58 PM
woodnthings
Here is what you do:
1) On the DTC tab, click the printer icon button (top right side on mine) or press F8
2)When the pop-up box appears, save the job to your AE folder or somewhere you can find it. It will save as an XML file.
3)Now you should be able to view the report and print it if you wish.
Here is the XML file when viewed in MS Word
Old Oct 30, 2011 | 04:03 PM
Skip1970's Avatar
Skip1970
thats great! thanks, so even if i dont have a printer i can save it? the reason i like ot save it, is because i would like to capture all the info and view it inside the house were its warm.
Old Oct 30, 2011 | 06:49 PM
woodnthings
Yes, it saves it to the drive, then you can print it out. If you use the computer with AE on it, you will notice it opens to a nice report.
Old Jan 23, 2012 | 05:41 PM
AllaboutMPG's Avatar
AllaboutMPG
Saved this thread a while back when I first thought about getting AE. Now that I finally got it and got around to starting to use it I went back and read this thread and several otherswere Ken(Woodnthings) posted about AE.
Reps at you Ken for taking the time to share so much good info about AE with the rest of us. SUre has been helpful.
