No power roling idle
Old Oct 28, 2011 | 11:11 PM
blueline970's Avatar
blueline970
I have an early build 2004 F250 with about 188k on it. In the morning I have been having an intermittent no power issue. I have tested the ficm and get 48v koeo and while ranking it. It idle fine once started but when I put it in drive and give it gas it just idles down the road. Put it in neutral and give it gas the rpms are slow to climb and turbo is slow to spool. Other days when I try to drive it will kind of buck and jerk. Also sometimes kind of shudder to life and others fires up. No long hard cranks.
Problems go away after driving couple blocks. Has done this when 100 degrees out and when in lower 40s.
I have installed a new icp sensor and still having same problems. I dont have any gauges unfortunately. Im going to check for chaffing but what else could be going on? Since it is something that comes and goes Im not sure what to check for.
If its one of the sensors can some post up how to check with voltmeter like what volts or ohms to look for.
Old Oct 28, 2011 | 11:45 PM
zhilton's Avatar
zhilton
Possible the accelerator pedal servo has a bad connection or is going out?
Old Oct 29, 2011 | 06:04 PM
blueline970
Dont know 6.0 bible if I read it right said that the PCM reads 3 different signals from the pedal and would set a CEL if 1 or 2 went out.
Old Oct 29, 2011 | 08:00 PM
BLADE35's Avatar
BLADE35
aAny recent work done to the truck??
Did you replace the ICP pigtale
Old Oct 29, 2011 | 08:07 PM
blueline970
ICP sensor that just started to leak pigtail appeared to be in good shape. Was doing same thing before replacing sensor.
Old Oct 29, 2011 | 08:17 PM
BLADE35's Avatar
BLADE35
Usually when the ICP pigtail is oil soaked it gets replaced to
oil could be messing with the ICP signal
was the pigtail not oil soaked and just leaking around the sensor
Old Oct 29, 2011 | 08:27 PM
BLADE35's Avatar
BLADE35
might try to get a codes read at the auto part store
Old Oct 29, 2011 | 09:14 PM
blueline970
Pigtail looked like it was in good shape it wasn't soaked. They able to check for pending codes?
Old Nov 2, 2011 | 02:26 PM
blueline970
Just an update. I have noticed since I replaced the ICP sensor the bucking and jerking have gone away when cold. I just have a rolling idle to take care of.
Old Nov 2, 2011 | 07:17 PM
BLADE35's Avatar
BLADE35
What exactly do you mean by a rolling Idel????
Old Nov 2, 2011 | 08:29 PM
blueline970
No matter how much pedal i give it the rpm will not go above 1000 until a block or two down the road. Basically only going as fast as letting off the brake pedal and the engine just idling.
Old Nov 2, 2011 | 08:53 PM
Piolet's Avatar
Piolet
Probably going to find out its the IPR too.
Old Nov 3, 2011 | 10:50 PM
blueline970
What is the easiest way to pull it and check it?
Old Nov 4, 2011 | 05:50 AM
bismic's Avatar
bismic
Since you are in Fort Worth, the easiest way is take it to Cheezit!
If you want to do it yourself, you will need to buy or make a socket, then you can get to it by moving the degas bottle and removing the FICM.
Old Nov 5, 2011 | 12:01 AM
blueline970
Probably do it myself. What size socket will fit on it? Probably pull it to check the screen on it when I do coolant flush.
