Horsepower or Torque?????
Old Apr 10, 2003 | 08:44 PM
maximumhorsepower's Avatar
maximumhorsepower
I used to think that horsepower was what I wanted to build for, but recently I'mnot so sure. I don't care about top speed, I want monstrous acceleration. Should I build for high horses or high torque? It will be a street vehicle.
Old Apr 10, 2003 | 09:18 PM
1976 ranger's Avatar
1976 ranger
I am currently building a 390 for My F250 4x4 and i building it for torque, as torque is what moves it off the line.
Old Apr 10, 2003 | 11:47 PM
Crowbar65's Avatar
Crowbar65
I think the old adage is..
"Horsepower sells engines, but torque wins races", so I would say build it for torque, LOTS of torque.
JMHO
Mike
Old Apr 11, 2003 | 01:35 AM
Scotty1's Avatar
Scotty1
Both torque and HP are related and are enhanced by much of the same components. More air and fuel with bigger spark= more. Some where around 450 Hp you will find nearly the same in torque. After that, with out power adders, you will see drops in toque compared to the HP. the torque will go up, but not as siginifacntly as the HP. this is an in general situation. I am sure there are ways to make more torque than hp and make gobs of it, but I am only aware of Nitrous or forced induction in order to make it. Hope this helps.
Scotty
Old Apr 11, 2003 | 07:32 PM
76supercab2's Avatar
76supercab2
Buy a tachometer. I will bet that you will be surprised how little time your motor spends above 2500 rpm. When you look at the mag reviews the test usually start at 2000 or 3000 rpm -- the rpm where you will be done most of the time. Horsepower is Torque multiplied by RPM (how fast can you do the work). So the easiest way to make more HP is to spin the motor faster. For a daily driver build for the MOST low RPM Torque you can. You will be much happier.
Old Apr 11, 2003 | 07:51 PM
BB's Avatar
BB
Now you'll have to change your username to maximumtorque.
Old Apr 12, 2003 | 09:29 PM
maximumhorsepower
I'll consider that, but maximumhorsepower sounds so good.
Hey thanks guys for your input. I know what I want now.
Old Apr 12, 2003 | 09:35 PM
Ratsmoker's Avatar
Ratsmoker
Please choose a proper title for this thread besides ????. It makes it nice for people who are searching for info related to the topic. Thanks
Old Apr 13, 2003 | 02:37 PM
maximumhorsepower
Sorry guys, I'll title them better from now on
Old Apr 14, 2003 | 08:02 AM
chrowen's Avatar
chrowen
Cam it for torque baby! Torque gets it going; horsepower screams it on the top end.
Old Apr 14, 2003 | 04:32 PM
Ratsmoker's Avatar
Ratsmoker
Horsepower is a fancy way of measuring torque. A 289 in a truck like mine could kick my butt off the line if it were geared right. When you throw in a bigger cam than the heads can handle you will loose both torque and horsepower. Why build an engine that needs to turn a billion rpms to get the same power as it could at a lower RPM? Same HP @ a higher RPM equals less torque which in turn equals the need for lower gears to get the same performance.
