352 Rebuild Suggestions
Old Apr 14, 2003 | 12:48 PM
1 TON's Avatar
1 TON
Here's what I've got so far,
1) Well used 65' 352 Block. Two bent pushrods #'s 1&8 intake
2) 390 GT 4BBl intake "The one with the large runners"
3) Pair C7AE Heads "Hopefully small chambers, I need to measure them
4) Holley 650 Vacum secondaries electric choke "Christmas present"
Now, This is going into a 65' F-350 with the New Process 435.
What do you folks suggest as far as cam, and pistons? I'm going to have to bore at least .030 will go to .050 depending on piston avalibility.
Would like to see compression ratio of between 9 and 10.
Suggestions and opinions?
Old Apr 14, 2003 | 04:48 PM
Ratsmoker's Avatar
Ratsmoker
Edelbrock performer cam and which ever pistons you like that bring you up to about 9 - 9.5:1. That would be my opinion. You have a lot of weight to move.
