Sponsored by: Real Truck
undercoat until spring
Old Oct 28, 2011 | 09:10 PM
onebadv2's Avatar
onebadv2
Okay, so I bought all the POR stuff and the repaint stuff and the cleaning stuff to completely clean, POR coat and repaint my undercarriage because of the amount of rust I have. Problem is, now the weather is too cold according to the mfg label for me to do the work an I do not have access to a heated garage/barn that is tall enough for me to get my truck in.
The question is....is there anything that I can spray on my undercarriage to help hold the rust at bay until early spring that will not cause me problems with painting at that time? If so, where can I get it and how hard is it to apply. Thanks in advance!!!
Old Oct 28, 2011 | 10:31 PM
cartmanea's Avatar
cartmanea
I would try this stuff: Ospho Rust Treatment - Since 1947
Old Oct 29, 2011 | 05:03 AM
BareBones's Avatar
BareBones
Get a kerosene-fueled (or propane) torpedo heater and direct it beneath the vehicle while you work and the paint dries?
Old Oct 31, 2011 | 12:49 AM
billybop90's Avatar
billybop90
May sounds corny but you can take used motor oil place in a spray bottle and squirt away. Just keep re-applying every few weeks until the weather gets warmer for your exterior work. Use to live in salt heavy michigan and it seemed to work very well, just remember to clean the undercarriage.
Old Oct 31, 2011 | 09:49 AM
bigblue61's Avatar
bigblue61
If your going to do something like this go with fluid film. Its pretty cheap and a hell of a lot better for the environment.
Old Oct 31, 2011 | 09:51 AM
MisterCMK's Avatar
MisterCMK
I've heard good things about Fluid Film. I am going to pick some up myself today.
Old Oct 31, 2011 | 09:53 AM
cartmanea's Avatar
cartmanea
Any kind of oil-based rust prevention is going to make it that much harder to achieve good adhesion when you treat your undercarriage in spring.
Old Oct 31, 2011 | 09:55 AM
ToMang07's Avatar
ToMang07
Be carefull doing this tho... too much heat can ruin the paint...or even melt plastic.... (Ask me how I know.)
That's my plan! lol
Old Oct 31, 2011 | 08:31 PM
pbeering's Avatar
pbeering
Use Fluid Film. Pm contact info for detailed guidance.
Old Oct 31, 2011 | 09:52 PM
billybop90's Avatar
billybop90
DOH!!!
Totally forgot about fluid film, would definitely go with this rather than used motor oil.
Old Oct 31, 2011 | 10:39 PM
cartmanea's Avatar
cartmanea
Remember, any oil-based protection will make using a rust encapsulator this spring more difficult since you'll have to thoroughly degrease everything.
Old Nov 1, 2011 | 06:36 AM
pbeering's Avatar
pbeering
Fluid Film is lanolin. It was designed to be removable. The washing with soap and warm water will remove it to allow the POR-15 application process.
On the back-side of the POR-15 application it is the ideal treatment for all the things that can't be painted.
I have sold lots of Fluid Film to folks, many here, for just this purpose, and have applied it before and after POR-15 application..
Old Nov 1, 2011 | 10:07 AM
cartmanea's Avatar
cartmanea
From their website, looks like it has petroleum oils in it:
"FLUID FILM is formulated from specially processed wool-wax, highly refined petroleum oils and selected agents to provide corrosion control, penetration, metal wetting and water displacement."
Old Nov 1, 2011 | 11:16 AM
bigblue61's Avatar
bigblue61
Fluid film will wash away from most parts of your truck by spring. There may be a few areas that you need to hand wash but anything exposed to the elements will wash away with time. I know that I usually need to coat my truck twice a winter. It generally removes pretty easily but using a degreaser may help a bit. I think its your best short term option
Old Nov 1, 2011 | 11:19 AM
pbeering's Avatar
pbeering
All true. However, and I speak from experience on my fleet and on that of several of my subs where we have painted the entire undercarriages, .when you do the recommended washing and etching prep, Fluid Film will not be an issue. POR-15 is an epoxy and it sticks quite well to about anything other than UHMW plastic. If one wishes to be a purist, or do a show vehicle, perhaps, but I don't think that was the point of the question.
