Alternator Quick Help
Old Oct 28, 2011 | 03:42 PM
cowmilker08's Avatar
cowmilker08
Question Alternator Quick Help
My amp meter is normally on the M after the GP turn off and it kicks in. This morning on the way to work it it was sitting on the N and every couple of miles it would go to the M for just a litte bit. The brightness of the head light followed the trend so I know its not the gauge/gauge wiring.
Could it be a wiring problem on the charging circuit? Or is it the alternator?
Old Oct 28, 2011 | 03:57 PM
bad12jr's Avatar
bad12jr
Check the single wire on top of the alternator. Mine came loose just enough that it acted funny. Found it while looking for something else.
Old Oct 29, 2011 | 12:01 AM
oldbird1965's Avatar
oldbird1965
If Jeffrey isn't right then its probably the alternator. I've gone thru three of them in eight years.
Old Nov 1, 2011 | 03:12 PM
cowmilker08
It was the alternator. When I took the serpantine belt loose, I discovered about 1/8" play in the shaft. Now the bad bearing noise at the front of my engine is gone. I thought it was an idler pulley bearing, turns out to be the more expensive alternator.
On the plus side the amp meter now reads on the 'A' and it starts up easier. Must have been a little low on voltage.
coolfeet
Jun 2, 2018 05:19 PM
npccpartsman
Oct 27, 2013 11:58 AM
Hussler
Jan 22, 2011 01:38 PM
grover
Nov 4, 2005 11:41 AM
superbepro
Sep 12, 2005 06:10 AM
