Head on over to the forums at - Bob is the Oil Guy You'll find plenty of discussions on the 7.3 and 6.0 there. Depending on your driving habits and the mileage, you may find many there that will tell you synthetic is just a waste of money. With that type of mileage though, I'd suggest getting a Used Oil Analysis from Blackstone Labs (about $25) and you'll find out whats really going on in that engine. There is a forum on there that posts some amazing analysis results from oil out of high-mileage 7.3's. Good luck!
True. However, the issue is that the lighter weight oil helps in the cold starts though. It allows me to jump in and start it unless it is that cold WITHOUT having to plug in the night before.
I have no doubt. And I'm sure less wear on the starter and batteries. However, my comment was to the OP who lives in FL, which is where my Ex does most of it's service.
I say go with the synthetic..it's just a piece of mind in my opinion.
I use Mobile 1 Turbo Diesel oil 5w 40. Not too badly priced, sometimes you can get it on sale at Walmart.
Synthetic oil viscosity stays more constant in a wider range of temperatures. I noticed that pouring syn at ambient temp, it flowed quicker than dino oil at the same temp. When warmed up, dino oil was flowing like the syn.
Isn't Rotella 5W40 whereas dino is 15W40? If so, that might explain the cold difference.
I am with the waste of money group. We run our diesels all winter and never plug them in while running 15w40 and no problems. Two of our diesels have over 400K miles on them now and running as good as always. In fact we are having more problems with salt ruining our trucks before the drivetrain going out...
How low can it go before it becomes a problem? With synthetic I can go to 20 below and start the truck when it has been sitting for a night or two. With 15W40, it seems to have trouble when it is 20 above and lower.
Well, you know the weather we get, both diesels have started every day all winter long since they were new. One is a 94.5 IDI turbo and the other was a 86 6.9 IDI. The 86 however has been retired for about 5-6 years now with about 460K miles on it. The 94.5 is still is service.
Being started every day may have something to do with it. Probably don't chill down to absolute ambient temp by the next morning.
I think running them every day also helps keep the batteries charged. When it's that cold out they don't hold a charge well. So the combination of the two must be helping you. Do you park them inside? Being out of that cold wind helps too, doesn't even need to be heated.
