Gas Gage not working
Old Oct 28, 2011 | 05:41 AM
Ki-Adi-Mundi's Avatar
Ki-Adi-Mundi
I just put a sending unit on my 78 f-350, the old one was terribly corroded. The gas Gage does not work, when the truck is comes on all the needle does is slowly rise to the E and I have 7 gallons of gas. The next thing I am going to do is to go into the instrument cluster but I wanted to first check if anyone on here had any ideas?
Thanks
Old Oct 28, 2011 | 05:42 AM
Ki-Adi-Mundi
The sending unit is brand new from LMC trucks
Old Oct 28, 2011 | 09:11 AM
fmc400's Avatar
fmc400
MSEE
Sounds like the ground at the crossmember (where the sending unit grounds) is lost. This is the next most common issue. Try running a jumper wire from the eyelet where the sending unit grounds up to clean sheetmetal on the bed.
Old Oct 28, 2011 | 10:39 AM
Ki-Adi-Mundi
There are two wires coming from the sending unit. You are saying Neither of these two wires are the ground?
Old Oct 28, 2011 | 10:58 AM
devino246's Avatar
devino246
One of the two is ground, but it may have lost the connection.
Old Oct 28, 2011 | 07:26 PM
BiltFordTuff's Avatar
BiltFordTuff
get a piece of wire that fits into the two holes on the plug (if it is a two prong) that goes onto the sending unit (i used soldering wire) and stick one end of the wire into one hole and the other end in the other hole. turn your key on and watch the gas gauge. if it goes straight from E to F, you have something wrong with the sending unit, but if not it is a wiring problem.
danielescoboza
May 4, 2013 06:19 PM
fordnurse
May 8, 2011 08:12 PM
hacking_in2002
Mar 23, 2011 10:18 PM
hugger94
May 21, 2009 12:01 PM
rlay302
Nov 3, 2004 01:17 PM
