Sponsored by: Real Truck
6.0 vs 7.3
Old Oct 28, 2011 | 12:03 AM
DesertStorm's Avatar
DesertStorm
6.0 vs 7.3
I am looking at two differnt trucks for sale in my local area that are actually affordable. I cant seem to decide on which one would be the best choice. Both from private party individuals.
#1-99.5 F250 supercab 4x4 long bed 6speed 7.3psd. 265k miles. Interior is good, paint is good, no oil leaks or abnormal noises all glow plugs recently replaced, less than 1 year ago. Ranch hand brush guard, rhino lined bed, 5th wheel hitch. new tires. seller asking 8000.
#2- 2004 F250 supercab 4x4 long bed torqshift auto 6.0 psd. 181k miles. Everything else between the two trucks is the same only difference is year, miles and engine. seller asking 10500. No seller knowledge of any head gasket repair or egr repair etc.
No service records on the #2 truck the #1 truck has some records of oil changes, glow plugs, and a clutch 40k ago.
Should I be more worried about the miles on the engine of the 7.3 or the high miles on the auto of the 6.0 truck.
BTW I have driven both trucks, they both start easy, no smoke on startup, no funny noises etc. Just never have had any experience with the 6.0's
Just looking for some honest opinions. Thanks.
Old Oct 28, 2011 | 12:35 AM
sammy77's Avatar
sammy77
Honestly, at that mileage you can expect "things" to happen no matter what truck you go with. The 7.3 is cheaper and easier to repair though. Good luck with whatever you choose.
Old Oct 28, 2011 | 12:39 AM
DesertStorm
I know "things" tend to happen with high miles, but i have seen many 7.3s with 500k miles and more still going, just concerned that the auto in the 6.0 has reached or is near its max life expectancy.
Old Oct 28, 2011 | 01:36 AM
hotroddsl's Avatar
hotroddsl
I would be less concerned with the auto trans than with the engine! 181k is pretty high mileage for a 6.0 & it will really start runningnup the repair bills with VGTturbo replacement head gaskets EGR cooler & oil cooler, if the guy hasn't kept a repair history on that truck it's an an absolute NO! The 6.0 is a fantastic engine, but it's expensive when it breaks, a rebuilt from ford is close to $15000.00 yes I ment to put that many 0's
I personally wouldn't worry too much on the 7.3 with a good service history 265k is not that high at 350k I would want compression tested &oil analysis before I made an offer! Just my $0.02 good luck
Jim & fat Monty
Old Oct 28, 2011 | 07:13 AM
spinella's Avatar
spinella
get an oasis report on the 04....the 99.5 is too old to get a report on.
Old Oct 28, 2011 | 11:23 AM
lllateralus's Avatar
lllateralus
Personally, I'd go with the 99.5 truck. Yes it is older, but it comes with 2 things that are known to be bulletproof. The 6 speed, and the 7.3.
The price is a couple thousand cheaper. That just seals the deal in my opinion.
(true, the 2004 is fluffier and prettier... but what are you looking for here? A high mileage truck..)
Old Oct 28, 2011 | 07:55 PM
Dim Sum's Avatar
Dim Sum
Opps! Wrong Forum post.
I would go for a 7.3 when it comes to those miles.
Old Oct 28, 2011 | 08:41 PM
Unrealo4's Avatar
Unrealo4
I wouldn't be afraid of the 6.0 mine has 157k on it. And it runs better then alot of 7.3's I know of. People are afraid of the 6.0. Use that as a way to drop some off the price. And keep it around for a rainy day. Who knows you may never need it.
Old Oct 28, 2011 | 09:40 PM
DesertStorm
Thanks everyone for the input, i was kinda leaning toward the 7.3 truck over the 6.0 anyhow, and the 7.3s are getting harder to come by. Its really hard to find any diesel truck for under $10k that doesnt have a ton of miles. So my choices are limited.
Old Oct 28, 2011 | 10:46 PM
baddad457's Avatar
baddad457
I bought my 99 with the 7.3/6 speed and have yet to regret it. And it had 258K on the odometer when I bought it. First thing I did was buy a new clutch, pressure plate and flywheel though as I could tell from the pedal feel that the clutch wouldn't last too much longer. Best part is though, I'll likely never have to touch the clutch again as I don't use it to shift, only to take off and stop. I passed on a 99 with an automatic that had 100K fewer miles, knowing that it was just a matter of time before the transmission would need 3 grand worth of rebuild. The 6.0/Auto? NEVER.
Old Oct 29, 2011 | 08:00 PM
FarmingF250's Avatar
FarmingF250
Out of the two, the 7.3 6-speed would be my pick...
I hate an auto, and I was warned away from the 6.0 from almost anyone I asked about it..
SATX210
Jul 12, 2016 04:07 PM
SilentlySoaring
Aug 9, 2012 10:25 AM
bobby84_00
Dec 14, 2011 06:20 PM
dutchhman
Aug 17, 2010 02:09 PM
Terryw5782
Oct 7, 2009 09:57 AM
