6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Exhaust in cab
Old Oct 27, 2011 | 09:32 PM
bohl345's Avatar
bohl345
Exhaust in cab
In the spring I blew up the motor and had it covered under warranty,it was a short block replacement. Two weeks later the high pressure fuel pump went. A week later the computer. Ive been running the truck daily now for two months and everytime I go into regen I get exhaust smoke in the cab. Brought back to dealer but they cant diagnose problem without it being in Regen.Had mechanic drive it home and it never regened so cant find it. Anybody have advice?
2008 f350 king ranch
Old Oct 27, 2011 | 10:11 PM
DRRXR's Avatar
DRRXR
A few
Posible hose leak
CCV leak
Hood seal bad
Up pipe leak
and turbo down pipe
6.4 PowerStroke bulletins
Do you smell it all the time?
Welcome to FTE
Old Oct 28, 2011 | 02:08 AM
golfmedik's Avatar
golfmedik
Usually a pipe misalignment. My work truck(F450) has one after it's first cab off repair. Took a while to find though. The second time it did it, it was the gasket in between the turbos that was leaking. The truck was put into manual regen by the tech and driven around. That's when he finally smelled what we were smelling. Good luck.
Old Oct 28, 2011 | 05:13 AM
senix's Avatar
senix
Have them do a manual regen and then they will know...its as golfmedik said. they just need to realign.
Old Oct 28, 2011 | 05:18 AM
bohl345's Avatar
bohl345
The leak only happens during regen and will also show itself thru the vent on the passenger side fender. I was told they cannot make it go into manual regen. I plan on bringing it back on monday.
Old Oct 28, 2011 | 06:28 AM
senix's Avatar
senix
go to another dealer. They can thru IDS command a manual regen.
Go to a place that has a proper Tech.
ATE88
Dec 27, 2014 05:58 AM
hank89
Feb 27, 2010 08:01 PM
twodivdeep
Jun 11, 2009 11:28 AM
Mid_Mo_F100
Nov 27, 2008 10:58 PM
jofford
Exhaust Systems
Jun 4, 2002 01:40 AM
