DP 4in down pipe clearance
Old Oct 27, 2011 | 03:19 PM
fromnwmt's Avatar
fromnwmt
I did consider asking in exhaust forum BUT looked like 90% gas engine questions etc. I did some search's and read as many as i could find about diesel aftermarket exhausts and still have a question, we are installing a Diamond Eye 4in cat n muffler elimination exhaust on my sons 2000 ford 350 heavy duty extended cab 7.3L power stroke, my question is how much clearance from firewall is do we need? i have read some needed to "modify" the firewall which i am ok with have saws-all & new blades i also read to not use the included clamps is there anything else we need to be aware of? sorry if i asked in wrong forum
Old Oct 27, 2011 | 03:40 PM
PaysonPSD's Avatar
PaysonPSD
I have no experience with modifying firewall for a DP. I installed a Magnaflow and not a Diamond Eye DP.
If u-bolt clamps came with the system they will certainy work but I used Walker band clamps instead of u-bolt clamps, except for the u-bolt with the hanger(rear most in the pic). For the actual connection I did use a band clamp. The u-blt hanger clamp is actually around the bad clamp. Just a matter of personal choice but the band calmps don't crush the connection and makes it easier to later adjust or separate the pipe connections if needed.
Old Oct 27, 2011 | 04:23 PM
JOHN2001's Avatar
JOHN2001
Those clamps are nice. I have a Banks 4'' turbo back I scored off CL awhile back and Ill admit it was a tight fit but it went in and bolted up like it should. What I did was made a heat shield where it was close to the fire wall and called it good almost 2 years and no issues
Old Oct 27, 2011 | 05:49 PM
fromnwmt's Avatar
fromnwmt
Thanks for the info the stock exhaust came out with no problems i was considering a heat shield of some sort, i was just nervous after reading some had to modify the firewall to create enough clearance, we just discovered they sent the wrong kit 2003-2006 so its going back so we have to wait to see how it looks and SOUNDS....
Old Oct 27, 2011 | 08:22 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I installed my 4" DP with no modifications necessary.
Old Oct 27, 2011 | 08:30 PM
Firefighter 1406's Avatar
Firefighter 1406
My 4" down pipe went in pretty easy just had to bend my tranny dipstick mount, but I am running into a problem with my tranny heat shield rubbing on the exhaust. I am going to have to get serious and really bend it I guess.
Old Oct 27, 2011 | 08:31 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Like I said, by DP went in fine with some finagling. My only problem is at the other end. It rubs on my rear shock..
Old Oct 27, 2011 | 08:51 PM
KJNDIVER's Avatar
KJNDIVER
I have a Diamond Eye 5" system with the 4" DP. I did not have to make any modifications for it to fit.
Old Oct 28, 2011 | 10:06 AM
fromnwmt's Avatar
fromnwmt
Sounds like a roll of the dice to see if we are lucky enough for everything to clear!! I will let you know how it goes, I cannot wait to hear it "breathing" ..... jwj
Old Nov 4, 2011 | 11:49 AM
fromnwmt's Avatar
fromnwmt
Received correct Diamond Eye exhaust yesterday (thur 11-3) it went together with zero fit or clearance issues!!! Took less than an hour and sounds GREAT!!!
Metalhead47
May 18, 2014 12:16 AM
ppd3180
21
Jun 15, 2011 05:28 PM
scrdanis
Connecticut Chapter
Mar 4, 2011 10:45 AM
Tungsten
Sep 18, 2008 02:10 PM
