PCV ???
Old 10-26-2011, 07:37 PM
sailorjohn's Avatar
sailorjohn
sailorjohn is offline
PCV ???
There is a long dog house on the back of my drivers side valve cover. Hose goes into the air intake between air filter and turbo. I am assuming that it is some kind of PCV. Should it be changed periodically?
Old 10-26-2011, 07:52 PM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Most of us do a modification to the doghouse.Here is the write-up.Some build the oil trap,others just run the hose like I did.
Welcome to guzzle's CCV mod web page
Old 10-26-2011, 08:37 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
No filter lives in the doghouse.
Old 10-26-2011, 08:43 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
There is no scheduled maintenance, but the last time I took if off I cleaned it out with some solvent and brake cleaner.
You don't want to remove it unless you have new o-rings for re-install. CCV O-rings at Dieselorings.com
Old 10-27-2011, 06:02 AM
sailorjohn's Avatar
sailorjohn
Thank you, I suppose since I'm in there I'll do the mod.
Old 10-27-2011, 07:43 AM
Ponyboychris
Hit it!
When I did the CCV mod, I built one of these to trap the oily mist before venting to atmosphere.
Ford Super Duty Man
07-15-2009 09:22 AM
Proxymatic
05-14-2008 10:01 AM
djmac
01-13-2004 09:15 AM
oldfordtrucksrule
03-04-2003 10:05 PM
i looove fords
02-09-2003 05:30 PM
Quick Reply: PCV ???
