Sponsored by: Real Truck
Max Towing Capaacity
Old Oct 26, 2011 | 06:49 PM
MauleOne's Avatar
MauleOne
I have a E99 F350 PSD automatic, 4x4 and I wonder what is the largest gooseneck trailer I can tow behind it?
I am looking at buying a trailer to make a long distance move but don't want to buy one that is too large for my truck.Yet I want to make my move in one trip and get everything in the trailer.
Thanks
Old Oct 26, 2011 | 08:35 PM
BigAlsPSD's Avatar
BigAlsPSD
Is it a DRW or a SRW? What gears? I don't know how much stuff you have obviously, but I would not think you would overload a gooseneck with household goods, although it is very possible.
Technically speaking you should be rated for around 12,000lbs to 13,000lbs for a GVWR of 20,000.
Old Oct 26, 2011 | 11:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
It depends on your gear ratio, SRW or DRW, chassis, and transmission.
I think this link will help.
http://www.hillerford.com/resource_l...wing_guide.pdf
Old Oct 27, 2011 | 06:53 AM
paulmac's Avatar
paulmac
TOWING
I HAULED A 10,500 PD LOAD 5.4 373 REAR END NO PROBLEM
MIKES 5 STAR TUNER 93 OCT GAS
Old Oct 27, 2011 | 12:44 PM
mwsF250's Avatar
mwsF250
What can it haul legally, or what can it haul capably?
Over mountains or just flat land?
Old Oct 27, 2011 | 02:57 PM
n7bsn's Avatar
n7bsn
You can get some idea by going to Trailer Life's Towing Guide
Old Oct 27, 2011 | 04:05 PM
onug's Avatar
onug
To answer the "legal" question of how much... Go scale your truck and note the weight distribution between axles. Then find the axle ratings for the truck, plus the GVWR and GCWR. Now for some simple math...
Max pin weight = GVWR-truck weight.
Max trailer weight = GCWR-truck weight.
And if you want to get more technical, make sure the pin weight doesn't put you over your axle ratings (and tires).
Old Oct 27, 2011 | 04:53 PM
MauleOne's Avatar
MauleOne
TOW
I need to check and see what my axle is before I can come to any conclusions.
Old Oct 27, 2011 | 08:48 PM
Kajtek1's Avatar
Kajtek1
I see 1-ton hauling those 55' goosenecks with 4 cars on them all the time. They are legal and they are capable. Are they completely safe? Fact is they usually drive below speed limits.
Old Oct 28, 2011 | 05:47 AM
paulmac's Avatar
paulmac
THERE WAS ALOT OF HILLS THIS WAS IN THE MIDDLE OF THE STATE OF MAINE MIKES 5 STAR TUNER MADE INCREDABLE DIFFERENCE I HAVE MORE TORQUE VERY HAPPY LAST TRUCK HAD V 10 2 VALVE 5.4 HAS NOT LET ME DOWN YET
Humph
All Things Towing
Sep 19, 2017 08:08 PM
jlsdcen2
2004 - 2008 F150
19
Jan 19, 2008 12:05 AM
captain p4
Aug 24, 2007 03:33 PM
rhinobenz
All Things Towing
Mar 30, 2003 04:01 PM
Antisimplistic
Oct 18, 2002 01:47 AM
