Block I.D.
Old Oct 26, 2011 | 08:59 AM
JLaw92's Avatar
JLaw92
Block I.D.
I bought a 300 engine complete minus intake/exhaust manifolds and I was wondering what markings there are to tell me what year the engine is. I plan on building it and didn't know if the years made any difference on parts. It is a carbuerated engine. Thanks
Old Oct 26, 2011 | 10:43 AM
85e150's Avatar
85e150
If you are going to go through it, all that really matters is that is was a carb'd engine. EFI motors had different heads which are still compatible with a carb'd set up with minor mods.
Casting numbers and a date code can be found on the block. The casting numbers will only tell you the year the revision took place, not when it was actually cast. The date code will tell you when it was assembled. Look for a machined flat with numbers stamped into it in the format in this link. I do not know where that is on a 300, but near the starter or near the oil filter are two favorite spots.
Date code is all the way down the page:
Classic Mustang Part Number Decoding Guide
76f350spercamprspeal
Apr 2, 2019 06:26 PM
AbandonedBronco
Dec 7, 2017 05:35 PM
clancassidy
Dec 24, 2006 11:46 AM
F250DOOOK
Dec 11, 2005 12:36 AM
buggered
Oct 26, 2005 04:32 PM
