ford block tags
Old Oct 26, 2005 | 01:40 PM
buggered's Avatar
buggered
ford block tags
how do you decode ford block tags?
the block i have has these marks: 2k09 k 303 b and under the oil filter it looks like rk4
Old Oct 26, 2005 | 03:01 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
The block tag.. Just a guess...from what i'am learning looks like 1962.Nov, 9th day?
Too find out for sur wait tell the code Guru checks in.....G, He can tell ya all about it!!
Russ
Old Oct 26, 2005 | 04:12 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
It could also be 72/Oct/09. The letter "I" is skipped for the month codes so as Russ stated it could also be a 62 just move up a month to Oct 9th. The 303 might be a 330 which would be the engine cid. B is the plant code which I don't know sorry. As far as the block date code the first character is always a number for the year. So maybe the date code is 2K4. If the 2 has two dots underneath it's a 70's casting. A 62 casting would have no dots and also 2 bolt motor mounts. Pretty easy to tell. There should be another number on the tag next to the B. The first two numbers indicate the year of the vehicle. G.
Old Oct 26, 2005 | 04:32 PM
1975Ford's Avatar
1975Ford
There should also be a Ford Casting Number, and are usually located below the heads on the engine block, towards the front of the engine. example: C5AE-6015-E
