4.0 Manual Tranny No 5th Gear
5Th gear is gone, any ideas???? It grinds going into gear but no output. I still have to use the clutch to put in gear but no results. That's the only gear giving me trouble. How difficult are these to tear down. I don't have much to lose, I have another vehicle to drive if I need to do something else after destroying while I'm looking for a replacement.
At least it is 5th gear (any other gear would be worse) Sometimes I don't even use 5th gear. (When towing my johnboat or driving in the hill country) Unless you are worried about miles per gallon and do some higher speeds on the interstate, I would wait to overhaul the transmission. Overdrive .... Who needs it? (J/k)
Yeah, no 5th stinks but it could be worse. I do a good bit of interstate and it is horrible having people pass me while I'm going 65. That's about 2,500 RPM's. I usually run about 80 at the same RPM so I feel like I'm crawling. I may try to find one that's already torn up and buy it to see if I can rebuild just so I have a spare before I tear mine apart. I know I can get it taken out without a problem, its just kind of iffy past that.
FordBronco4life94
45
01-23-2011 01:32 PM
Rumrumm
04-14-2008 11:35 AM
