Old Apr 10, 2003 | 03:48 PM
cr8zy4millissia's Avatar
cr8zy4millissia
Question !
Well, I just talked to the man that I am buying it from today. I know more about it now. It is a 1969 Ford F-250HD, 390 V-8, 2 Barrel Rachester Carb, 2 WD, 4 Speed Manual Tranny, 4/11 Rear Gears, Floating Rear Axle, 17 1/2 inch front rims, 17 inch Rear Rims, new clutch and new stuff, chrome skull shifter handle.. Only few problems are as follows;
1. Needs new tires
2. Needs new water pump (GONE)
3. Needs new Speedometer Sheild or cover (heat warped)
4. Needs new or re-hupolstered seet
4. May have dash issues.
That seems to be all it needs. From what I hear, it raced an IROC Z Camaro and beat the hell out of it. So, I still want more opinions on the truck.... Should I buy it or not? He wants 800.00. Only problem I see in it is, it is not 4 WD. I Wyoming, it is a very usefull aspect.. Expecially where I work.. Ranch! So, what do you all think. Also, I am selling my 75 Chevy C-30 1 Ton 2 WD with a 3 Speed Auto Tranny, 350 V-8, 4 Barrel Quadra-Jet Carb, 1 ton Rear end, floating rear axle, needs interior work, has some dents, 20 some gallon fuel tank, single tank, chrome engine part from Edelbroch. It has 16 inch rims. Had dry rot on both front tires, rears are 1 size or so smaller than fronts, and needs new starter. All other work has been done and the truck runs PERFECTLY. So, I want a possable price on it. I am looking at at least 1,500. I put at least that much into it. Thanks everyone.
