Hey fellas, Ok heres what I have, I am installing riffraffs apiller gauge kit, and Im need a bit of help or tips. Starting the wireing, and was how much wire play I should leave between gauges. Also and tips on when drilling the hole for the pyro and where to drill it on the manifold? thanks and pictures would be great thanks
I just got the Isspro package from riffraff also. That link shows the sensor in the up pipe, Wouldn't it be better to go into actually manifold that is thicker material so I would have at least a few threads to tap. Also, is it necessary to drill holes in the stock pillar, the directions say there is enough room behind the new pillar.
The link I posted shows it drilling and tapping the manifold right before it turns up into the uppipe...
Diesel manor guide is great! Only advice I have is take your time, dont get frustrated and try to rush it... if you do you'll end up in the standing in the rain at 12 am with your interior torn half apart (dont ask me how I know). Also if you are using a fuse tap for the power source, make sure you put two fuses in the tap spent 2 hours trying to figure that one out because Im a bit slow on the up take... That being said the wiring is a easy as long as you follow the diagram that comes with the gauge.
