Rough idle 300 I6
Old Oct 25, 2011 | 11:39 AM
acom01's Avatar
acom01
Rough idle 300 I6
My 1995 300 I6 beguins to shake a little at idle. Plugs ok, injectors ok.
Doing a revision, the problem is cilinder nro 1. It has lower compresion.
All cilinders 160-170 psi, nro 1 120 psi. Chek the lifters..ok
Wath could be? A piston ring? a valve? the camshaft lobe?
Old Oct 25, 2011 | 03:32 PM
1983F1503004x4's Avatar
1983F1503004x4
Low compression can be due to a number of things such as the valves not sealing properly on their seats, the head bolts might not be torqued all the way down, or a bad piston ring.
I doubt the head bolts aren't torqued properly because it's only on one cylinder.
Unless you changed the cam in your truck, the lobe is more than likely fine. Worn cam lobes can happen mainly due to a lack of break in grease on the cam lobes of a new motor, and this flattens them out within the first 20 minutes of running.
You said the lifters were okay. Since yours is a 1995, you should have non-adjustable rocker arms. If you need to adjust your valve lash at any point, get adjustable push rods. That's the only way you can adjust valve lash, as the rocker arms just torque to spec.
Loose valve lash won't cause low compression though.
If it's just the #1 cylinder, it might be a piston ring.
How long has it been since you changed your motor oil and filter?
I recommend trying Seafoam on your motor first. It cures loose/sticky lifters and frees piston rings.
Sea Foam | Home
Old Oct 26, 2011 | 06:10 AM
acom01's Avatar
acom01
Last oil change was about 2000 miles ago. i´ll try with sea foam and see what happens. I wish is just a sticky ring and not a broken one.
Thank you very much!
Mikes63
Dec 22, 2011 08:24 PM
xrufx
22
Apr 5, 2011 01:02 AM
robwymer
17
Mar 4, 2009 02:22 AM
72amcamx
May 24, 2007 05:37 PM
Steve78
Sep 4, 2006 10:44 PM
