Fuse Block?
Old Oct 25, 2011 | 02:20 PM
GB SISSON's Avatar
GB SISSON
Why didn't I think of that? I'll attack it after work. I have to act like I'm interested in cabinet job # five hundred and something for a while so my employees don't turn on me.
Old Oct 25, 2011 | 02:43 PM
baumst's Avatar
baumst
I sell car wash soap, so I have to pretend the public is out washing their cars.
I was eating lunch on my last response here, sitting in my truck and I am answering you... Solving my problem, I am just going to run a new light from Napa Auto Parts from those wires I found and be done with it. No harm no foul, probably work better.
Old Oct 25, 2011 | 09:04 PM
spurredon's Avatar
spurredon
The fuse block per se just "presses", on on to the head light switch. The tab from the head light switch go into female connectors on the rectangular fuse block. You should be able to lift it off from the switch and examine it better.
Old Oct 25, 2011 | 11:13 PM
GB SISSON's Avatar
GB SISSON
Thanks for all your help. I removed the instrument panel and found the press in button to remove the stem from the switch. Of course it was rusted so I had a tough time getting it pushed in. Finally I pulled the stem and the switch. With some cleaning and a little re routing of wires, I now have panel lights and idiot lights(unfortunately the charge light stays on) so now it's generator/regulator time.
Old Oct 26, 2011 | 07:32 PM
spurredon's Avatar
spurredon
A lose belt will also give you a Gen lite. Of course, loose connections will as well.
Old Oct 27, 2011 | 09:46 AM
GB SISSON's Avatar
GB SISSON
I cleaned all three terminals on the generator, then removed the cover on the regulator. I found with the engine at idle you can manually touch one set of points together and they arc just a bit and then stay contacted. At this time the gen light is off. I assume this means the generator is putting out. I also found that if I turn the ignition off at this point, the light stays on (discharging at rest). Can I assume the generator is operating, and the problem is in the regulator? Electrical has always been my worst area.
marine dad
Sep 3, 2019 05:21 PM
Smoking Joe
Jan 15, 2018 08:26 PM
natedog37
Jun 25, 2014 01:49 PM
ENCSDEI
Feb 21, 2009 10:53 AM
Way2phat
Oct 14, 2007 02:33 PM
