Fuel Filter Change Need help fast
Old Oct 24, 2011 | 05:01 PM
WilliesSD250's Avatar
WilliesSD250
When did the switch occur with the fuel filters for our trucks? I always used the 1847170c92 (now 1847170c94). The new primary filter is different than what I took out (the end that goes first into the housing. What gives? and what is the correct part number?
Old Oct 24, 2011 | 07:04 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Yes they changed sometime back. Not sure of the International new #. Ford's is FD-4616.
Old Oct 24, 2011 | 07:07 PM
amdriven2liv
They seal better. So what you have is "New and Improved!"
Old Oct 24, 2011 | 07:20 PM
WilliesSD250
so they will work? I couldn't seem to get the cap to seat all the way.
Old Oct 24, 2011 | 07:33 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
They're tougher to tighten, but it helps a lot if you lube the o-ring well.
Old Oct 24, 2011 | 08:21 PM
zhilton's Avatar
zhilton
The filters changed about a year ago. Navistar 1847170C94 is the number...or at least that's what I've got written down. The Ford p/n is 3C3Z-9N184-CB.
Old Oct 24, 2011 | 08:28 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
The change was done to provide better sealing of the filter to the housing and prevent unfiltered bypass/leakage.
It does require a little more force to install. I use a torque wrench when tightening my filter cap and I have to go real slow or I'll get a premature torque click of the wrench before the cap is fully seated. Just make sure the cap seats on the flange face of the housing and you should be good.
green_95
18
Aug 30, 2016 10:45 PM
skoveng
Mar 14, 2011 03:10 PM
bismic
Jul 13, 2010 08:45 AM
cbd2
6.4L Power Stroke Diesel
May 20, 2010 09:24 PM
ehgeeray
Apr 15, 2010 07:32 AM
