Super Swamper Irok
Old Oct 24, 2011 | 04:16 PM
Stinky7-11's Avatar
Stinky7-11
Super Swamper Irok
Anyone have any feedback on this tire? Its made in a radial and i bias ply, radial costing more i want to use a 39.5 x 13.5- 16 on my 77 F250 with a 6" suspension lift
Has anyone had a fit problem with this setup?
Tony
Old Oct 24, 2011 | 07:17 PM
ford1977owner's Avatar
ford1977owner
shouldnt have a problem with it, you can fit stock 35s on these trucks
Old Oct 25, 2011 | 09:18 AM
Stinky7-11's Avatar
Stinky7-11
If you guys that run 39.5 tires on your trucks could give me some feedback before i order me it would be great also so photos. for now i have a stock 400 runs strong,C6 and 4.10 gears.
Thanks
Old Oct 25, 2011 | 11:26 AM
i-w's Avatar
i-w
i had 39.5 x 15.5 x15 bias tires and hated it. i have 35x 12.5 BFG A\T inch radials and
love them.the bias ply tires seem to bounce at times like a basketball. they also get
flat spots if they sit for too long. the BFG i have now are great except they rub the
radius arms if i turn too sharp. But the 39.5 were rubbing everything real bad. plus it
seems the steering was ral hard unless i was moving. if i was stopped and had to turn
the wheel the powersteering could not do it.
79 F150 351M C6 Short box.
4 inch lift 3 inch body with 39's
Old Oct 25, 2011 | 11:46 PM
Stinky7-11's Avatar
Stinky7-11
Anyone else care to chime in? I really need som photos
Old Oct 26, 2011 | 12:19 PM
hairyboxnoogle's Avatar
hairyboxnoogle
To be honest no one can really tell you if they will or wont rub. Realistically you will have to climb under it and measure, or test fit. With a 6" lift im sure you can mount them, but i think you will rub with the suspension compressed and at the right angles. The amount of offset you have can really help. If necessary there is always more lift or cut-out fender flares. If you plan on driving the truck on pavement mostly i would steer clear of the bias. Great tire.. definately not made for the road. You will get flat spots, theyre nearly impossible to balance and i would bet you dont get more than 8 or 10k miles out of em. They also ride like solid tires. The radials will ride better, handle better, and last longer.
Next thing to consider, to run a tire that big you need to look at dual steering stabilizers and possibly hydro assist steering (different than power steering, similar to the steering on hi-boys) I notice yours is a 77, is it a hi-boy or a 77.5? From what i have heard the hi-boy steering is great for big tires and can be upgraded fairly easy.
Old Oct 26, 2011 | 02:08 PM
Rich Halsey's Avatar
Rich Halsey
I was shopping for some Swampers also. OMG they are expensive!
03DexterHauler
Nov 23, 2011 08:27 PM
Kuskoal
May 13, 2009 12:34 PM
98cobra1064
34
Jul 5, 2006 02:28 PM
theguy_88
Feb 10, 2006 11:19 PM
90ebbronc
1978 - 1996 Big Bronco
Jan 29, 2004 09:27 AM
