Parting Out '95 F250 4x2 with a PSD, ZF5, Standard Cab
Category: Drivetrain
Price: $1000
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: OH
Shipping Information: Item can be shipped
Engine: Part suitable for diesel truck
Fiberglass cap -- SOLD
Also have my 203* Dieselsite thermostat for sale. Has less than 5,000 miles on it, but doesn't fit the water pump housing on the '95 motor I swapped into my truck.
Rear Axle, springs, etc, -- SOLD
Here is a quick list of the things I still have available:
4x2 ZF5 "kit"
The entire front suspension
Rear anti-sway bar
Both fuel tanks, sending units, filler necks, etc
Compete regular cab in good condition
XL cloth bench seat
Engine wiring harness
Cab wiring harness
Gauge cluster
'96 Powerstroke 7.3 Liter engine -- parting out
4x2 ZF5 "kit"
Rear anti-sway bar
XL cloth bench seat
Cab wiring harness
Gauge cluster
Yes sir. I have it all, the transmission, the drive shaft, the floor pan, the pedal box, slave and master cylinder, even the manual PCM if you want it. I even have the dual mass flywheel that came out of the truck, although I would suggest replacing it with a single mass flywheel while you're at it.
Not sure what type of mirror you need exactly. The ones on the parts truck are the hoop type. Not the electric (small) or the towing (large) but the....I don't know what you call them....Ones like this. And they're not in great shape...I think one of them has a dent in it But if you want them I will make you a good deal on them.
It looks like the mounting holes are on the underside of the upper bracket? If so, those are what I need. Mine have some surface rust so I figure it's time to get some others. Can you send a pic of the dent?
Real nice truck, by the way...
Thanks again
Thanks again
Ok, I will snap a shot or two of the mirrors tomorrow morning and send them to you so you can see what kind of shape they are in. It is a nice truck, but its not mine. Just a picture I found that has that style mirrors.
Alright, I don't know if these are better than the ones you have or not. There appears to be some light surface rust starting on the top brackets, and you can see the dent in the driver side mirror. I won't be offended if these aren't what you want. Let me know if you want them. And we can work something out for the price and shipping.
Thanks!
Thanks!
#29
Bump to the top. Still lots of parts available. Still have the ZF5 kit. Somebody is going to get a deal on this transmission. Willing to sell the transmission by itself if someone needs it. Many engine parts still available as well. Cylinder heads, HPOP, Fuel bowl from a '95, oil cooler, transmission adapter/spacer, tail lights, headlights, turn signals and markers, dome light, engine wiring harness, engine compartment wiring harness, stock intake, stock exhaust in good condition, complete and un-opened (fully charged) A/C system, complete red interior, lots more. Shoot me a PM and make an offer on what you want.
