rear swaybar
Old Oct 24, 2011 | 01:35 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by timmyboy76
Greg, you notice an upgrade in handling..etc, now that its installed
Gigantic difference when towing a fifth wheel. Feels like a dually instead of a SRW truck.
The airbags also have something to do with that as well....
Old Oct 24, 2011 | 01:38 PM
timmyboy76's Avatar
timmyboy76
IF the seller doesnt have the "extra" parts needed, and just the bar itself, and after i'm done chasing the parts needed, if they're anything close to this, then i know what route to take...
http://www.amazon.com/Hellwig-7677-R...ar=1&carId=001
Old Oct 24, 2011 | 01:41 PM
timmyboy76's Avatar
timmyboy76
Good to know, chief...my truck get goin purdy good when i'm loaded, and the route i take, its nothing but hills/turns, even though its 75 miles from home, it takes an easy 2-1/2hrs to get there...just to give an idea
Old Oct 24, 2011 | 01:53 PM
BigAlsPSD's Avatar
BigAlsPSD
It does mount to a bracket held with U bolts.
Old Oct 24, 2011 | 01:58 PM
timmyboy76's Avatar
timmyboy76
Alan, i wonder if "stock" is where your mounts at, and the "hellwig" uses the backside ofthe shock perch. You look at Greg's pics? Completely different mount location/setup
I have the "notch" atop the axle tube, like yours, where the u-bolt rides in...beginning to think now, that a stock bar will not bolt up like a hellwig setup???
Old Oct 24, 2011 | 02:05 PM
BigAlsPSD's Avatar
BigAlsPSD
Mine is factory, it looks like the Hellwig uses the U bolts for the shock mount. The bolts that hold the shock mount on mine are long enough to easily mount the sway bar bushing bracket onto as in Greg's setup.
Old Oct 24, 2011 | 02:18 PM
timmyboy76's Avatar
timmyboy76
Yup, mine too Al...gonna look around for prices on these parts.
Old Oct 24, 2011 | 02:46 PM
timmyboy76's Avatar
timmyboy76
Heres something weird, energy suspension has the swaybar bushings, right, but it list them to be both, front and back application. So, i'll measure the bolt width of my front swaybar, and see if it matches up with the u-bolts for the rear shock mounts. Also, from the look of the E.S. pics of bushings, where the bolt holes are at, they look to be slotted...
Al, do you think your stock swaybar can be mounted up to the rear shock perches?
Old Oct 24, 2011 | 07:33 PM
BigAlsPSD's Avatar
BigAlsPSD
I would have to look at it again, I cannot at this time, but length between bolts appeared to be the same, the bushings just slip so it's very likely.
sirkingdra
Oct 2, 2017 12:17 PM
cecilt
Feb 9, 2017 01:44 PM
afhanson72
Aug 14, 2015 12:49 PM
tworock
Aerostar
63
Dec 18, 2005 08:03 AM
wolffee
Sep 15, 2004 02:59 PM
