EPDM roof leak
Yes repair replace the damage wood if it is soft. After the repair glue the rubber roof back down. Use six inch wide roll of EternaBond to seal all seams in that area. Also use the EternaBond any other seams on your roof no more leaks after that!! EternaBond comes 50' & 25' rolls it is expensive but is the best for long last repairs
Working carefully, I do think you will be able to make a suitable repair.
Good luck,
Steve
New skylight installed with tacky tape and new, larger screws.
Dicor and the first strip of Eternabond. The water really pools behind the skylight due to the slope of the roof.
I'll wait until the Dicor cures a bit more to put the rest of the Eternabond around the skylight.
The front cap seal of the trailer is next inline for new Dicor and Eternabond as alot of water also pools there. The vents, antenna, and reefer vent also need new Dicor.
I'll scrub the entire roof with TSP first to get it all clean before I continue with those projects. Then it's all new clear silicone on marker lights, windows, etc.
HVFDFIREFIGHTER1618
06-05-2019 07:41 AM
maverick600
29
12-27-2018 06:27 PM
