ELECTRICAL!!!!!
Old Oct 23, 2011 | 02:07 PM
99F350bigorange's Avatar
99F350bigorange
ELECTRICAL!!!!!
I have a 1999 F350 7.3 and the starter solenoid was going out and so I replaced it about two days ago and its been working great I don't have to use a screwdriver to start the truck anymore. Until today I had to pop the hood and use the screwdriver again!!! Any ideas as to why this thing has gone out again already??
Old Oct 23, 2011 | 03:04 PM
Bonanza35's Avatar
Bonanza35
Know help here but what our you crossing. Have a picture?
Old Oct 23, 2011 | 03:24 PM
PaysonPSD's Avatar
PaysonPSD
If I am not mistaken, and I could be, the ground for the winding is supplied through the backplate of the relay and if blackplate doesn't make good contact with the fender the relay will not operate. Check continuity of the mounting bolts to ground and continuiy of the bolts to mounting plate.
For starters just loosen and re-tighten the mounting bolts.
Old Oct 23, 2011 | 04:59 PM
timmyboy76's Avatar
timmyboy76
i'm taking, he's jumping the 2-post on the starter relay, located on the p/s inner fender well.
Old Oct 24, 2011 | 04:19 PM
99F350bigorange
Alright that sounds good Im going to try and clean up the contact for the mounting plate and bolts and go from there. Thanks everyone!
AMGrulz
Nov 16, 2014 09:51 AM
eithernet2010
Oct 19, 2010 01:41 PM
Talyn
Jul 16, 2010 07:42 AM
deetown
Apr 20, 2008 02:52 PM
timbersteel
Oct 3, 2007 11:21 AM
