Sponsored by: Real Truck
Auto Transmission Help
Old Oct 22, 2011 | 08:15 PM
aqhacountryguy's Avatar
aqhacountryguy
My 1999 F350 SD 7.3L auto transmission is dead, I have a chance to buy a rebuilt but need to determine if 4R100 serial # RFF81P-7006-AA-02 will fit. Help as my time is running out to make this deal. It is Lariat 4x2
Aqhacountryguy
Old Oct 22, 2011 | 09:14 PM
57meteor's Avatar
57meteor
if the number is F81P-7000-AA it is off a 99 f250/f350 with a 5.4.that is too light for a diesel.and am not sure if it would fit the 7.3 block.would need more numbers off the tag on the trans to be sure what it is.
Old Oct 22, 2011 | 11:53 PM
aqhacountryguy
Serial number to look for that can be used on 7.3L
Thanks for the heads up about the tranny, won't spend my money on that transmission. What numbers should I be looking for on the casing that will match up for a 7.3L.
aqhacountryguy
Old Oct 23, 2011 | 12:15 AM
57meteor's Avatar
57meteor
there is a tag on the left rear of the case.that is the numbers a person needs.even if it is a rebuild,you will know what the case came from.i need to know if it is 2or4wd and if it has a pto to get you some numbers.you could also look at the old trans and try match numbers off of it if the tag is still readable
Old Oct 23, 2011 | 12:20 AM
aqhacountryguy
My F350 is a 2wd and no PTO. Thanks for the help, I'll read the numbers tomorrow and get back to you.
Aqhacountryguy
Old Oct 23, 2011 | 12:37 AM
57meteor's Avatar
57meteor
here are some numbers F81P7000HB or XC3P7000HA.model number PRB-G or PRB-AV
chads496
Sep 29, 2013 12:51 PM
Brendan Vares
Aug 24, 2012 04:07 PM
HardFordCore
Dec 11, 2005 02:29 PM
dmc919
Jun 2, 2004 08:36 PM
fordmanSLO
Oct 11, 2001 06:57 PM
