Stuck Wheel
Old Oct 23, 2011 | 02:50 PM
Fordranchero's Avatar
Fordranchero
Loosen the nuts and make several sharp turns while moving, always works for me.
Old Oct 23, 2011 | 06:55 PM
boggerted's Avatar
boggerted
loosen them up and back into a curb as hard as you can that always does the trick. Did you find out if your drivers side is reverse thread? I believe it was like that up until 87
Old Oct 23, 2011 | 06:58 PM
joshofalltrades's Avatar
joshofalltrades
i don't believe any 80s trucks used the reverse thread on the left side. i've owned and worked on several and haven't run into that. now the 60s cars i had growing up all had the reverse thread, but even on late-70s trucks i've only found right-handed threads
but thread direction isn't helping the OP any
Old Oct 23, 2011 | 07:18 PM
kneisl99's Avatar
kneisl99
Yeah I loosened them with just moving back and forth about 50 feet but that wasnt stressing the wheels enough.
These are the rear wheels though so they dont turn like the front wheels do...
Old Oct 23, 2011 | 07:21 PM
kneisl99's Avatar
kneisl99
Havnt got to the drivers side yet but when I do if they ARE left hand threads I will mention it.
Yeah I like the curb idea. When my son can come over and help with the impact gun thats the first thing we'll try.
Old Oct 23, 2011 | 07:53 PM
FL299's Avatar
FL299
You could also try backing off the nuts and then jack (floor jack) the opposite side up so it is clear of the ground. Then push the truck sideways in the direction of the loosened wheel with a shaking motion hoping the weight will help shake the wheel loose. I have also used a porta power between the wheel, with a piece of 2X4 against the tire and the other end against the blocking or into a hole in the ground. I also prefer blocking to jack stands on a job such as this. Almost forgot - you may also want to use a long drift and hammer on the axle when you have pressure on the porta power.
Old Oct 23, 2011 | 07:56 PM
Otahyoni's Avatar
Otahyoni
On my 86 all the threads on the entire trucks are right hand thread save for one side of each tie rod (for adjustment). The lugs are all right hand threads.
I can't beleive how stuck that must be if you've done everything suggested and still havent got it....
I guess the last option is heat.... I say last option because i dont know if that will ruin the wheel....
Old Oct 24, 2011 | 11:42 AM
Rollin.IH.Coal's Avatar
Rollin.IH.Coal
Hook a chain to her.... =)
Old Oct 24, 2011 | 01:12 PM
joe f350's Avatar
joe f350
or have the tire blow out in ur face thats never good
Old Oct 24, 2011 | 04:50 PM
boggerted's Avatar
boggerted
My 84 F250 had reverse threads on the rear drivers wheel
Old Oct 24, 2011 | 08:16 PM
Otahyoni's Avatar
Otahyoni
That is really weird boggerted...
Old Oct 24, 2011 | 09:46 PM
bio-d's Avatar
bio-d
I just had the same problem a few days ago. I slowly let the floor jack down until the weight of the truck was bearing on the wheel and it popped loose. I had to do it a few times and rotated the wheel in between
lowering. I did have a safety block in place in case the jack went down too fast or slid sideways.
Mike
Old Oct 25, 2011 | 01:52 AM
  #28
joshofalltrades
boggerted, are you saying it was only the left-rear wheel - then i would have to say that either someone swapped out your rearend or they replaced all the studs after breaking a few, and chose the LH thread because they were just used to it from older trucks. either way, its not normal for the time period
Old Oct 25, 2011 | 04:31 AM
  #29
cj06's Avatar
cj06
did the tire ever come off ?
Old Oct 25, 2011 | 06:39 AM
  #30
bashby's Avatar
bashby
Had a friends 83 f350 cab/chassis with left hand thread on the LR.
