fuel pump issue??
Old Oct 22, 2011 | 12:55 AM
Crittenden74's Avatar
Crittenden74
fuel pump issue??
I've recently purchased an '06 sd 6.0 ps. When it shifts into overdrive it cuts out and seems as though its running out of fuel. I've been told to drain the excess water out of the hfcm, I did so with no results, the truck still cuts out. Any idea what the problem is?
Old Oct 22, 2011 | 07:22 AM
npccpartsman's Avatar
npccpartsman
First and foremost: WELCOME TO FTE!!!!!!!!
Take some time to read the tech folder at the beginning of the 6.0 forum. It has answers to a LOT of problems and lots of repair procedures that you can do yourself before/instead of taking it to a dealership. We have some VERY GOOD Ford Master tech's that frequent this forum willing to give you advice at their own expense.
1). Get your truck code scanned. Many autoparts stores can/will do this for FREE. Ask for the SPECIFIC codes and post them here for the most accurate help.
2). Post as much specific information about your truck and it's maintenance history as you can; mileage, filter and brand, oil and brand. These are all very important.
It's probably NOT the fuel pump although it's possible. If you haven't done so or don't know it's maintenance history I urge you to change the fuel filters ASAP using Racor, Motorcraft, or IH fuel filters. You can purchase OEM filters from dieselfiltersonline.com for a greatly reduced price than what you'll get them from a dealership.
Old Oct 22, 2011 | 10:41 AM
Crittenden74
Thanks, I will be doing all these things.
Old Oct 22, 2011 | 11:12 AM
NewToDiesels's Avatar
NewToDiesels
You'll do well then... Welcome to FTE!
David Wray
Apr 15, 2018 03:29 PM
blue oval fan
6.7L Power Stroke Diesel
51
May 5, 2012 03:39 PM
jquise2423
Jun 1, 2010 01:24 AM
04turbo
Jun 9, 2005 08:17 PM
steelman 1999
Jan 14, 2005 05:25 PM
