Driveway stains
I use a product called 'Dunk', which is just a parts cleaner, and I spray it on the area and work it in with a bristle brush. Then I spray it good again, and break out the speed-dry. I spread it on 1/8 inch thick, and take out a sanding block with a good 40-80 grit paper and grind the speed-dry into the concrete thoroughly. I use circular motions at first, then finish in the direction of the concrete swept finish (if broomed). Don't be afraid to use more speed dry if you still see the stain. Finally, get the garden hose or pressure washer, and rinse it away!
Try it, you'll like it! Works on sidewalks and asphault streets as well.
Enjoy!
From wild western Canada
Mark
You need the following supplies:
-2 12-packs of beer
-Boom Box
-Golden oldies music
-A couple of buddies
-Bag of oil dry or clay cat litter
To make this work, you need to consume a lot of the beer, scatter litter or oil dry all over the stains, then do the twist, Chubby Checkers style, on the oil dry etc. This will bring stares from the neighbors but it you have consumed enough refreshments you won't care. Tell them they can join the party but they have to BYOB...
BTW- You will need a broom or a hose the next morning. DO NOT attempt to use the shop vac or you will be struck down by the neighbors and the morning after beer gods.
Mark
You do have a patent on that idea don't you? You could use used oil on any tennis court or B-Ball court and turn them into skating rinks. Sounds like a huge money maker to me
As far as the brick mop... Tie a brick to a rope around the dog's neck and let him drag it around. Keep both hands on the beer so it does not spill
It is called "Oil Hockey".
They are having a special season of the sport in Kuwait right now. BIG rink, just made; Bricks cost less there too, apparently.
Mark
