Which glove box liner?
Old Oct 20, 2011 | 08:23 PM
Orange '63's Avatar
Orange '63
Which glove box liner is correct for the 66 F350?
C1TZ-8106010-A (for 61-64)
or
C5TZ-8106010 (for 65-66)
Since the cab is the same as 61-64 I was planning to order the first one but just wanted to make sure that was right so I don't have to return it.
Old Oct 20, 2011 | 08:39 PM
99hosss's Avatar
99hosss
Hey partner I'm in Traveler's Rest, and take care of the Suntrust Bank in Gaff. Let me know if you need any help w\ the rebuild. I'm sure dennis carp. can help w\ the box info.
Old Oct 20, 2011 | 09:07 PM
Orange '63's Avatar
Orange '63
That's kind of ironic because I live in Gaffney and work for a company in Greenville. I'll remember to lay on the horn a bit next time I pass the Suntrust Bank.
-Luke
Old Oct 20, 2011 | 10:40 PM
Bill W's Avatar
Bill W
well i think it would depend on which heater you have in the cab.
Old Oct 20, 2011 | 11:47 PM
garbz2's Avatar
garbz2
The 65 66 F350 heater is a hodgepodge of early and late parts. It is the same as a four wheel drive using the early cab. You need to use the 61 to 64 glove box liner. Drivers side will have the pull vent and passenger will have the round fresh air intake above the triangular cowl vent for the cab.
Garbz
Old Oct 21, 2011 | 04:01 AM
Scifi266's Avatar
Scifi266
I remember putting in the glove box liner for my 66 I remember using the box that seemed to have cleft for the heater as mentioned in previous posts. I got lucky and got mine out of a pick'n'pull where i live in great shape.
Old Oct 21, 2011 | 11:39 AM
Buzz44's Avatar
Buzz44
Use the 65-66. Should be the same as my 65 4x4. Its the glove box with the step back to clear the heater. 66 cab should have the same heater as the 65. Best bet is to post up a pic of exactly what you have for a heater. Or see if NumberDummy will come to your rescue. If your heater box looks like this you will need the glove box with the step back.
Old Oct 21, 2011 | 02:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1TZ-8106010-A
or
C5TZ-8106010-A
C1TZ-8106050-A .. Glove Box Compartment
Applications: 1961/64 F100/1100 / 1965 F100/250 4WD 120" wheelbase / 1965/66 F350/1100 / 1966 F250 4WD 120" wheelbase // 1963/69 N/NT/T500/1000 / 1967/69 F800/1000.
C5TZ-8106050-A .. Glove Box Compartment.
Applications: 1965/66 F100/250 115" & 129" wheelbases.
Any of y'all have the 1964/72 Ford Truck Parts Catalog on a CD? If so...guess what? C5TZ-8106050-A was omitted (not listed-parts catalog error).
I had to get the info from an older truck catalog that cover 1957/68. AFAIK, only "Squire" Don and I have this older catalog.
Old Nov 20, 2011 | 07:33 PM
Invader6's Avatar
Invader6
Thanks NumberDummy, I was about to ask this same question for my 1965 F100. Great info.
Old Nov 21, 2011 | 04:39 PM
camperspecial65's Avatar
camperspecial65
Thanks Bill...it is not on the CD...theres other books that do have it as Bill mentioned..To pull the glovebox liner the heater needs to be pulled though...at least that applies to the C5TZ liner...I just pulled one a couple days ago at a local wrecking yard...
- cs65
68murc
Ontario Chapter
17
Apr 11, 2015 11:34 PM
jrockdiddy
Dec 8, 2014 01:00 PM
77whiteranger
Oct 3, 2010 01:18 PM
RedSS454
Jan 19, 2009 05:23 PM
