Bearing race ?
Old Oct 20, 2011 | 08:11 PM
arkredneck's Avatar
arkredneck
Bearing race ?
So I took apart my front end to put in some Yukon axle shafts and my outer bearing race just fell out of the hub its 6 months old and not tore up looks fine but still doesn't seem good
Old Oct 20, 2011 | 10:47 PM
Talyn's Avatar
Talyn
Thats the bearing cup. To be technical.
Anyways, it needs to fit in there snug, if its not, it will cause you a headache.
The only fix for it is to use something like bearing set, which I have not seen any of in a long time, or to buy a new hub.
I had to do this (both) on my f150. luckily the guy's place I worked on it at had bearing set.
It works like loctite, but resists different style forces.
It lasted a few months till I had the money to replace the hub properly.
If the cup has no damage on it, the seat for it is probably spun out in the hub.
Old Oct 21, 2011 | 07:57 AM
Neal 97 250's Avatar
Neal 97 250
I would probably try a new bearing and race.
It is worth the peace of mind.
The race should have to be driven in with a punch.
Old Oct 21, 2011 | 07:58 AM
arkredneck's Avatar
arkredneck
Well that sucks I bet Dana 60 hubs ain't cheap
Old Oct 21, 2011 | 09:22 AM
Neal 97 250
I would not get a whole new hub unless the new race does not fit in there snug. Just get a gearing. it should come with a new race.
Tap it in there and pack the new bearing re-install.
I can't remember the price I would say around $20 -$25 ???
Old Oct 21, 2011 | 09:23 AM
Neal 97 250
Also a hub from a D60 or D50 will work. Easy to find at a scrap yard.
Old Oct 21, 2011 | 11:42 AM
Brown Falcon's Avatar
Brown Falcon
Yep, just put the hubs from a '97 D50 on my '94 Dana 60 front I'm using in my 4x4 swap...
Everything fit great.
Old Oct 21, 2011 | 12:30 PM
dclack's Avatar
dclack
Not mine https://www.ford-trucks.com/forums/1...and-gears.html
If it will fit in a flat rate box, shipping won't be too bad either.
Old Oct 21, 2011 | 02:25 PM
arkredneck's Avatar
arkredneck
I got 97 Dana 50 setting around I'll check and see but the Dana 60 looks bigger
Old Oct 21, 2011 | 04:14 PM
dclack's Avatar
dclack
Nah. Hubs, rotors, brake calipers, spindle locknuts, and lockouts are the same for the 50 and 60. The brake components are limited by the years, but everything else is interchangeable from '85-'97.
Old Oct 21, 2011 | 04:47 PM
arkredneck's Avatar
arkredneck
My spindles have seen better days to
Old Oct 21, 2011 | 08:23 PM
Blueheart's Avatar
Blueheart
I have pinged a hub before for the same problem, use a center punch to ding up the surface where the race drives in, makes it tight again.
Old Oct 21, 2011 | 08:28 PM
Action4478's Avatar
Action4478
Go to a bearing supply dealer & get a product called "quick metal"
JB weld will work also ...
Old Oct 21, 2011 | 08:39 PM
arkredneck's Avatar
arkredneck
I'll probably jb weld it The truck is just a toy not a dd
Old Oct 21, 2011 | 10:14 PM
Talyn's Avatar
Talyn
bearing cup!
not race!
