Speedometer
Old Oct 20, 2011 | 05:51 AM
midsouth's Avatar
midsouth
Speedometer
My speedometer makes a clicking sound. I understand the cable can be removed, greased, and replaced. Do I need to pull the dash, or can the cable be accessed otherwise?
Old Oct 20, 2011 | 07:40 AM
TheKirbyMan's Avatar
TheKirbyMan
The gauge cluster can be removed without taking out the entire dash.
You remove the wiper **** (insert a bent paper clip into the bottom of the back of the **** and pop loose a little clip inside it),
The headlight **** (reach under the dash and feel for a push-button on the headlight switch; press it and pull the **** and shaft out of the switch)
Remove the plastic bezel around the gauges,
Then undo the four screws holding the gauge cluster in. Two up top near the turn signal bulb sockets, two in plain sight at the bottom of the cluster.
You can then -gently- pull the cluster out enough to press on the flat area on the end of the cable while pulling it out of the gauge. You may have to disconnect the big wiring connector on the right-hand side of the cluster if you don't have enough room to get to the speedo cable. It's a tight fit, lol.
If you can't get the cluster out enough to disconnect the cable, you can disconnect it from the transmission first, feed yourself some slack, and that will give you enough room to pull the cluster out more and disconnect the cable from the gauge.
Seems like a lot of work at first, but I had the cluster in my truck in and out so many times when I upgraded to a tach-equipped cluster, I can do it in my sleep now. lol. It becomes easy once you get the hang of it lol
garagegods
Jul 3, 2015 06:02 PM
aj88V
Mar 27, 2015 01:19 PM
Ehkart
Nov 8, 2009 06:34 PM
MikeWilder
Mar 13, 2008 01:10 PM
fordor
Jan 1, 2008 11:53 AM
