4R100
Oct 20, 2011 | 01:44 AM
4R100
Are all 4R100 trans from a SD diesel the same? My friend has one sitting in his shop and he said i can use that one to get rebuilt and give him the one in my truck so that we can just swap it out in one day.
Oct 20, 2011 | 07:20 AM
the only difference i am aware of is the 01 has diods in them that can cause issues...
Oct 20, 2011 | 08:30 AM
The 4r100 from a gasser engine has a different tail housing.
Oct 20, 2011 | 10:25 AM
Ok thanks guys. So I guess the internals are the same.
Oct 20, 2011 | 10:38 AM
Quote:
Originally Posted by
kupaa
Correct. Iirc the differences in the tails have to do with the number of splints on the tcase shaft.
I was told the 4r100 gasser tranny was stronger b/c of the beefier shaft.
Oct 20, 2011 | 01:18 PM
jkidd_39
The diesel 4R100's have stronger internals compared to the gas 4R100, except for the 4R100's used for the Gen 2 Lightning's.
The Gen 2 Lightnings have the same internals used in the diesel 4R100's.
Stewart
Oct 20, 2011 | 01:41 PM
Stewart_H
Stewart
Interesting info Stewart! Guess that's a mute point for our application since jw and BTS have better options.
Know anything about the rear shafts between the two Trannys??
Oct 20, 2011 | 03:34 PM
jkidd_39
Nope. It wasn't something we discussed on the Lightning boards I used to be a part of years ago.
Stewart
Oct 20, 2011 | 06:04 PM
jkidd_39
The difference is in the bell housing. Diesel uses a different bolt pattern. A gasser tranny will not bolt to a diesel.
All gas and diesel 4R100s use the same tailshaft.
Oct 21, 2011 | 08:39 AM
And all 4x4 transmissions have a different tailshaft than 4x2 transmissions.
Oct 21, 2011 | 04:11 PM
You also have PTO and non PTO versions. Here in AUS they are mainly the PTO version. JW told me you cant put a non PTO version into a PTO truck. Different gears and sensors apparently.
This cover plate indicates PTO version
Oct 21, 2011 | 09:10 PM
JW is wrong. You can put a non-PTO trans in a PTO truck. You just won't have the PTO function.
Oct 21, 2011 | 09:24 PM
since we are talking trany, wat yall think of the bts vaulve body?
Oct 21, 2011 | 09:32 PM
slim613
Love mine!! At 325k on my stock tranny and BTS vb. Get one!!
Oct 21, 2011 | 09:46 PM
jkidd_39
cuz im gonna do mods and wanna keep my trany on a safer side
