Are you guys familiar with the rumble sound like radial tires do when coming to stop?
That's the kind of sound my brakes are making when coming to a stop, and my radial are not beefy, what the heck is that sound, is not your classic squealing
that you hear everyday on the streets that goes away when sprayed with quiet brake ink.
Did you have the rotors turned recently? If not, if the vehicle sat for a while it may have a rust spot where the pad sat against the rotor. Look at the rotor and turn the wheel if it does, you should see it.
