ECT and EOT question
Old Oct 18, 2011 | 08:14 PM
dakotajeep's Avatar
dakotajeep
Finally got a gauge so I have accurate information. Edge Insight arrived the other day and I have put a few hundred miles on it since.
Cruising my delta is no more than 8-9 degrees but my temps hover around 170F while cruising empty at 55mph. The only time that I saw 190F was when I pulled my boat. Just curious if this thing is running cold.
I was under the impression that a cold running engine made the mileage decrease.
Just curious for your thoughts...
Thad
Old Oct 18, 2011 | 08:27 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
I just checked my temps the other day. My truck was running 190 to 200 water temp unloaded. If urs only runnin 170 unloaded. That's to low. Should b around 190.
Old Oct 18, 2011 | 09:01 PM
U.P. Builder's Avatar
U.P. Builder
Time for a new thermostat, that ect is way too low. Mine ran low also, not that low but around 180 unloaded. After replacing the thermostat it now runs 188 - 190 all day, a little more if pulling a grade or towing.
Old Oct 18, 2011 | 10:01 PM
weldworks54's Avatar
weldworks54
Mine ewt also ran low mine was in the mid to high 160's change the thermostat now it's up to 190 all day and also running a lot better
Old Oct 18, 2011 | 10:20 PM
Dieselpop's Avatar
Dieselpop
As stated get a new Ford t/stat and o-ring mine run ECT 194-196* EOT 200*
pop
Old Oct 19, 2011 | 06:52 AM
npccpartsman's Avatar
npccpartsman
Thad
That used to be the case for a gas burner but not for fuel injection and definitely not on a diesel. You'll get better engine efficiency running at the correct temperature especially when the PCM is looking for a particular set of values for optimum performance.
fordboy2
15
Nov 9, 2017 11:31 AM
ACEN
Jan 8, 2013 12:27 PM
oldfart
15
Mar 1, 2012 07:15 AM
cmdevildog16
Nov 7, 2011 09:11 AM
77Custom100
Jun 11, 2003 06:30 PM
