1978 - 1996 Big Bronco
Different model Ford steering box?
Old Oct 18, 2011 | 01:32 PM
Matt In Detroit's Avatar
Matt In Detroit
Is there a direct replacement ford box with a better ratio that could be ordered instead of a Bronco box? Just curious. I know about the read head boxes. Not going that route.
Old Oct 18, 2011 | 03:45 PM
Encho's Avatar
Encho
The Southernmost Mod
Almost every big sedan and truck from Ford in the period between 1964 and up to 1997 share the same Steering Box, i guess you should start researching specs. to see if any of them has a different ratio.
Old Oct 18, 2011 | 05:00 PM
Kemicalburns's Avatar
Kemicalburns
besides the cost of the ReadHead unit why not go that route? they put out a great product and there customer service is outstanding.
Old Oct 19, 2011 | 08:40 AM
Boss351Bronco88's Avatar
Boss351Bronco88
I believe the 1st gen Lightning's boxes were "tuned" by SVT for a quicker turning ratio. Ive thought about looking more into it myself.
Old Oct 21, 2011 | 06:42 PM
ErrorS's Avatar
ErrorS
Redhead will do custom ratios if all else fials, i know you said No, but just in case?
and yeah, other than a lightning I don't think you'll find a tighter box. I can't even confirm about the lightning, I've driven one and it felt just as loosey as my Bronco.
Be aware, I *know* the Bronco and F150 boxes are ANNOYINGLY low ratio, loose and sloppy even at 100% condition, but if you start toying with higher ratios you'll get to the point really quickly where you will feel like you're driving with manual steering.. I would also look into a better steering shaft, it doesn't take much to destroy one steering without PS (like when the truck is off), just with a few feet of steering, let alone replacing with a higher ratio and driving it all the time.
of course, if you're running stock tires then you should be fine.. still, don't know where else to go other than Redhead.
and Encho, I dunno how true that is.. my 78 f150's box is reverse rotation, my 90 isn't. Pretty sure Crown Vic boxes are shorter (but wouldnt bet on it) and that's about as tight as you'll find in the Bronco's size range.
Old Oct 21, 2011 | 11:55 PM
Edgethis's Avatar
Edgethis
I thought once upon a late night on FTE searching the forums that you could put a Crewcab Longbed 250/350 steering box on and it had a tighter turn to compensate for vehicle length..however that could be relevant to only the dentside I used to own. Food for thought maybe
Old Oct 22, 2011 | 07:45 AM
b4hntn's Avatar
b4hntn
I love my RedHead Steering Gear. It keeps getting better over the couple of years I have had it.
Old Oct 24, 2011 | 05:14 AM
Matt In Detroit
My low tech research of a handful of car part websites shows consistently that a lightning and a Bronco get the same part # for a steering box. So the theory that a lightning box has a tighter ratio isnt looking to be true.
xringonly
Jan 16, 2014 10:12 AM
Brown Falcon
16
Apr 19, 2011 04:24 PM
bluef72
Sep 6, 2009 08:25 PM
McLeod
1966 - 1977 Early Broncos
Jun 9, 2007 07:08 PM
palmercomputes
Dec 17, 2006 02:01 PM
