white smoke!! HELP!!
Old Oct 18, 2011 | 02:43 AM
radray73's Avatar
radray73
I have a 01 F350 i just had some of the injectors replaced. Now i have white smoke every time i start it. I think that it maybe my gp relay that is out and i would like to test it before i get a new one. i have power when i drive it but the white smoke only goes away when the motor is hot had the heads tested the are OK not losing oil or coolant. the hot air relay wont get power i read that it only kicks in when gp relay has turned off.
Old Oct 18, 2011 | 07:09 PM
F350-6's Avatar
F350-6
How long has it been since you did the injectors? White smoke is normal for 50 - 100 miles while you purge the oil and air out of the system.
Old Oct 18, 2011 | 09:27 PM
radray73's Avatar
radray73
i had 3 replaced a month ago it didnt smoke then and then it started to smoke about 200 miles after they went in they just replaced 2 more and it is still smoking. I have the grey square gp relay can it be test to check if it is good or bad.
Old Oct 18, 2011 | 11:43 PM
Bonanza35's Avatar
Bonanza35
It can be tested easy enough. I don't have the details someone should chim in. Did you change the glow plugs while you were in there? If injectors are bad glow plugs are cheap. Ohm them out also. How cold is it there?
Chet
Old Oct 18, 2011 | 11:47 PM
BigAlsPSD's Avatar
BigAlsPSD
Grey square as in Glow Plug Control Module?
Like this
If so I think you will need a diagnostic tool to test fully.
Old Oct 19, 2011 | 12:07 AM
radray73's Avatar
radray73
yes that is the one, it is about 80 i live in victorville ca its the high desert. No the didnt replace the gp i had it done on a warrent that just expired so i didnt have to pay much to get them fixed
Old Oct 19, 2011 | 07:23 PM
F350-6's Avatar
F350-6
Where did you get the injectors? Some rebuilds just don't work as well as others and can cause problems like this.
If you've got a GPCM, then if you have any glow plug issue the CEL will come on and trip a code that can be read by any code reader.
SHOpar
Feb 6, 2014 04:07 PM
rowekmr
Jan 19, 2013 08:09 PM
arkredneck
Dec 3, 2011 09:16 PM
savage250
Nov 4, 2010 12:41 AM
STROKIN'IT7.3
21
Sep 24, 2008 02:41 AM
