Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Help selecting CLASS 3 trailer hitch for escape
Old 11-19-2013, 10:58 PM
scott91370's Avatar
scott91370
scott91370 is offline
I haven't seen any in a class 3. But since the Escape can only tow 3500 are you sure you need the class 3? Or is it that you need the 2" receiver (only on class 3) and square tubing?
Old 11-22-2013, 11:28 AM
eazrider's Avatar
eazrider
eazrider is offline
I am looking to use the 2" receiver to mt a cycle carrier, max weight of 300lbs. I need to weld an additional mopunting point to the hitch to counter the tendency of a single point mt to want to wobble around. I can probably do it with the round tubing everyone uses, but much simpler with the square tubing.
Old 11-22-2013, 12:36 PM
scott91370's Avatar
scott91370
I figured it was for something like that.
What I would do, if you can't find a square (which looks bleak) is instead of welding, drill a hole all the way through and use a bolt with a washer front/back and a nylon nut to hold the support member in place. Don't forget to touch up the paint after drilling to keep the rust away.
Good luck.
Fmullegun
2004 - 2008 F150
12-08-2012 10:18 AM
wblgday
Crossovers
10-14-2012 07:10 PM
snakedoc
21
04-25-2011 11:24 PM
Steamships
1978 - 1996 Big Bronco
02-10-2005 08:21 PM
gblakeney
1997-2006 Expedition & Navigator
04-30-2002 08:42 PM
Quick Reply: Help selecting CLASS 3 trailer hitch for escape
