what class hitch do i need?
Old Apr 24, 2011 | 09:23 PM
snakedoc's Avatar
snakedoc
I think i have a class III hitch on my truck what ever came on the truck form ford rated for 5000lbs. do i need to get a class IV 8000lbs or V 15,000? our trailer weighs 2300lbs dry and the tractor weighs 4700lbs = 7000lbs if i dont have an attachment on the tractor. do you think a IV is ok or do i need a V, i hope to 1 day get a ~7x18 enclosed trailer and dont wont to buy a new hitch 2 times. i dont wont the thing to brake and hurt someone so what do you suggest? i dont wont a 5 wheel or goose hitch i need my camper shell to put stuff in and the trailer.
Old Apr 24, 2011 | 09:50 PM
Franko72's Avatar
Franko72
Molon Labe
You should have a class 4 hitch if it came from the factory. 10,000/1000 tongue. At least thats what I have seen on most superdutys. All three of my past ones had a class 4.
It should be all you need. Class 3's are worthless.
Old Apr 24, 2011 | 09:55 PM
snakedoc's Avatar
snakedoc
most of the class 4 i have seen only say 8000 but if it is for 10000 then i'm good as gold thanks.
Old Apr 24, 2011 | 10:00 PM
big poppa's Avatar
big poppa
Mines a class 4 but on my FIL previous 06 EB Excursion 6.0 he had the class 5 hitch. You'll be cool with the 4....
Old Apr 24, 2011 | 10:02 PM
aklim's Avatar
aklim
I am more worried about the liability of hauling more than what the manufacturer specifies as the truck's abilities. Pulling the load is one thing. Stopping is another. If the brakes are not good enough and you have an accident, well, my lawyer is going to have a field day.
Franko72's Avatar
Franko72
Molon Labe
Mine is factory and it sais 10,000/1000, 12,000/1200 weight distributing.
I also have a class 4 from a F250 that I parted out that is a (IIRC) Reece, or one of the big names that sais the same weights as the stock hitch.
Either way you should be ok. I googled the specs and It said class 3's are good for 6k, class 4 10k, and class 5 12k. They may have changed over the years
twags6's Avatar
twags6
The towing specs in the owners manual list 10,000lbs max for the hitch on both the 250's and 350's, which would be a class 4.
Old Apr 24, 2011 | 10:03 PM
twags6's Avatar
twags6
It seems like those numbers change a little from one mfg to another. I've seen some class 5 that are good up to 18k!
Old Apr 24, 2011 | 10:08 PM
snakedoc's Avatar
snakedoc
well for the most part i dont have to worry about that to much. in AL if you are hauling with your farm truck you can get away with no tag on the trailer and as long as the load is not so big it wont fit down the road you are good. some of the things i have seen where 23 feet wide and took all of the road, and you dont have to have a permit. got to love AL.
Old Apr 24, 2011 | 10:17 PM
bama29fan's Avatar
bama29fan
Mine if rated for 18k but its not stock
Old Apr 24, 2011 | 10:19 PM
Franko72's Avatar
Franko72
Molon Labe
I've always wondered what the little pin holding it all together was rated for?
Old Apr 24, 2011 | 10:25 PM
snakedoc's Avatar
snakedoc
mine says 5000 weigh and 10000 with a wdh. the trailer dose not have a wdh so is that ok or a bad thing waiting to happen?
this is what i would like to have 18,000lbs http://search.cartserver.com/search/...s=gl2211&GO=GO!
Old Apr 24, 2011 | 10:38 PM
bama29fan's Avatar
bama29fan
That is the one I have.
Old Apr 24, 2011 | 10:40 PM
snakedoc's Avatar
snakedoc
how do you like it and will it work with the 2" hitches to pull smaller trailers?
Old Apr 24, 2011 | 10:46 PM
twags6's Avatar
twags6
Found this over at rv.net Unfortunately it doesn't list the numbers on the catalog page anymore.
Draw-Tite list their locking pin sheer strength at 15000 lbs for 1/2 inch and 31000 lbs for 5/8 inch.
Page 110 of the following document:
http://www.rhscales.com/trailerhitch...ccessories.pdf
