E-350 Need a Guru
Old Oct 17, 2011 | 09:26 AM
UncleRock's Avatar
UncleRock
E-350 Need a Guru
Is there a way to r & r the power steering pump
Without yanking the rad etc.
Any spec sheet anywhere
I've searched the tech/article section and found nothing.
(Just after doing the oil to water cooler heat exchanger without having to unbolt the engine. (on f-350 not van) I have hope. Dont want to cut down the rented gear puller to make it fit
Anyone??
Rock
Old Oct 17, 2011 | 11:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It would help to know what year and what engine.
Old Oct 17, 2011 | 12:55 PM
UncleRock's Avatar
UncleRock
Aw my bad
1994 E-350
7.3L diesel (non turbo)
Old Oct 18, 2011 | 10:55 AM
UncleRock's Avatar
UncleRock
Question
Anyone help with this?
I looked at cutting down a flaring tool to squeeze it in, but not sure that would even work?
Old Oct 19, 2011 | 03:35 PM
Rick1025's Avatar
Rick1025
I did mine on a 95 with a gas engine from underneath.
Old Oct 21, 2011 | 11:00 AM
blageurt's Avatar
blageurt
I don't know about yours with the IDI but on mine with the powerstroke you need to remove the AC compressor , upper rad hose , engine fan shroud and the lines then you can access the pump ...Rad removal is not required on the powerstroke......
Reckless7
Feb 19, 2016 02:16 PM
darryl97420
Oct 2, 2014 05:08 PM
jojeep
Nov 2, 2013 04:31 PM
adamtheman16
6.7L Power Stroke Diesel
Aug 25, 2010 10:55 PM
Farmer XLT
Jul 4, 2004 09:41 AM
