1973 F-250 Power Steering Question
<VAR id=yiv455012087yui-ie-cursor></VAR>I have a 1973 F-250 3/4 ton pickup I think the part is called a power steering stabalizer but not really sure cause there is 2 power steering lines going to it. might be the original part.
any info. would be greatly appreciated
Thanks,
Sheldon
Cell: 701-477-2467
Thanks,
Sheldon
Cell: 701-477-2467
It's the Garrison power cylinder you need, about $250 thru NPD, contact this forum member in the following thread (PhilD), he bought a Garrison by mistake, he'll most likely give you a good buy on it.
https://www.ford-trucks.com/forums/1...l#post10888400
The Garrison power cylinder is about an inch longer than the Bendix power cylinder, so either they sent you the wrong one, or you have Bendix power assist and not Garrison.
Garrison was used '73-'74 up to serial #T80,001
Bendix was used '74-'77 up to serial #Y20,001
Maybe you have an earlier cab on a later chassis?
The Bendix/Garrison power cylinders look identical other than length, the control valves on the other hand are obviously different, which does yours look like in the link below?
http://www.stangerssite.com/TruckCVrebuilding.html
'MerricaBoy
10-14-2012 10:10 AM
bootsman
03-26-2006 12:14 AM
754x4f100
01-04-2005 07:20 PM
